Question about Whirlpool GHW9100L Front Load Washer
Washer does not fill
Just installed new washer today-- water pressure is sufficient, drain hose is not siphoning, but tub does not fill properly.
Only about 2 inches of water enters tub and then machine proceeds to g tumble/agitate and go thru cycles.  Is there a water level switch or something that needs to be adjusted??  Any suggestions will be appreciated.
  • 1 more comment
  • subswo Jan 27, 2008
    I have the LG WM--2277HW as well. I have had it almost two years now. I know its supposed to use very little water etc.. but alot of the time many of my clothes come out still dry in the middle. I have never thought it used enough water. Is there an adjustment that can be made to increase the water even a little bit. Im not asking for a swimming pool but I think the clothes should actually get completely wet.
    Im not using extremely large loads. It has happened with as little as 3 pairs of jeans.
    My valves are completely open, the hoses are not kinked. When I first got the set LG sent a local repairman out and he said everything was fine but also noticed that the load we put in while he was here was dry in the middle.
    Thanks in advance.
    Shannon and Matt
  • HelpPleaseqq Jan 08, 2009
    I have the same problem and the clothes are not cleaning and the whites are now looking dingy. I have not found a good solution. Does anyone know a good solution to get more water in the washer? Please help! (yes, the clothes are sorted properly. yes we've checked all valves etc. yes, we have tried all cycles.) Help!
  • lucyandboys May 11, 2010
    barnsleymick answer basicly sucks, trying to justify the poor performance for the energy saving ratings manufactures are trying themselves to justify. So can anyone actually answer Matt's question?!? How do you increase the water level???
  • 209 Answers
Many new machines use what we would only describe as hardly any water, does it do the job properly, if so then fine leave it as is,
this is calculated by computer so that the lowest level of water is used to do the job, hence the lowest amount of electric is used to warm it up, (a bit like filling the kettle to the top for one cup of coffee,its a waste)
its not what we see that matters, its what it does, after all we don't generally sit and watch it do we?
Posted on Oct 14, 2007
My washer is flashing LF
LF error code indicates that there is a water supply problem.
Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on. The washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked? Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged? Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details.
Is the water pressure less than 10 psi? If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe? The drain hose may be too far inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shaped drain hose form as described in the Installation Instructions will provide the appropriate length of drain hose in the drainpipe or laundry tub.
Check it and keep us updated. remeber to rating this free answer and leave some testimonila comment.
Oct 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
How to Prevent Washer Siphoning
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
  • The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
  • The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
  • DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
  • DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
  • The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
I hope these tips are informative and will help prevent some of the more common washer drain problems that can easily be mistaken for a more serious problem. You can save yourself a service call, just by double checking your installation.
on Dec 04, 2009 | Washing Machines
Tip
Basic Washer Installation Advice
Here are some installation tips for washing machines. This is meant to provide BASIC guidance and not meant to deviate from any installation criteria that may come with your washer. Follow your manufacturer’s recommendations if they differ from those outlined here:
- Water pressure requirements should be a minimum of 10-25 psi to prevent fill valve leaks and proper fill rates. A minimum pressure is required to keep the fill valves closed when not in the process of filling. If the water pressure is too low, you may experience symptoms of water filling in the wash tub when not in use and/or longer fill times.
- The drain line should be capable of handing 17 gallons of water per minute. If not, you could experience overflows from the standpipe during the drain cycle.
- The standpipe should be 2 inches in diameter, be a minimum of 34” from the floor to prevent siphoning, and should not exceed 72 inches in height. DO NOT seal the top of the standpipe, or place the drain hose too far down into the pipe. This can also cause siphoning. 4 to 6 inches is sufficient when placing the drain line into the standpipe.
- The operating temperature for the washer should be above 60 degrees F. It is not safe to place a washer in an environment where it is allowed to freeze. Residual water in the drain lines, fill hoses and pumps could freeze and damage the washer. This is something to consider when placing a washer in a location outside the home like a garage.
- The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- When leveling, make sure the washer is level SIDE-TO-SIDE and FRONT-TO-BACK, and that you place the washer on a FIRM foundation. Weak flooring is the number cause of washer vibration and out-of-balance problems. If the flooring flexes when the washer is in the spin cycle, the washer will vibrate, no matter if it is level or not (this is particularly a problem with front loaders). If you do not have an alternative, the flooring can be firmed up by placing a 4 x 8 sheet of plywood (at least ¾ inch thickness) under the washer to help distribute the weight more evenly.
I hope these tips are informative and help prevent some of the more common washer problems that can easily be remedied by double checking your installation.
Cabrio WTW7600 model, error code LF comes, checked water pressure and it is ok. Help
This LF error code indicates that there is a water supply problem. Are both the hot and cold water faucets turned on? Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
Is the drain hose taped onto the drainpipe? Is the top of the drainpipe covered with tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure the top of the drain is at least 39" (99 cm) high (as measured from the floor). If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction, (siphon) and the water will continue to drain out of the washer.
To remove the error display, press Pause/Cancel once.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Hope this helps (remember to rate this answer).
Jun 28, 2011 | Whirlpool WTW6400SW Cabrio Washer
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Tip
on May 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Tip
Basic Washer Installation Tips
on Feb 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is filling up to wash but water goes out of tub before
Mar 16, 2009 | Washing Machines
Want to know how much water my model 44092 washer should use.
Mar 15, 2009 | Kenmore Energy Star 44092 Front Load...
Hot water comes, but does not fill the Washer, and therefore does not rotate the tumbler. It is a Maytag commercial washer
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
Jan 28, 2009 | Washing Machines
Whirlpool GHW9100L Front Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal De
