Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A
Frigidaire Mod FFC05C2AW1 freezer won't cool, hear something running, the light over the thermo. isn't on either. Any ideas?
    Sergeant:
    Champion:
  • 214 Answers
Please switch off your refrigerator for at least 5 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage....... please visit your service authority
Posted on May 14, 2009
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Trouble shoot Frigidaire upright freezer?
Thank you for your inquiry, friend!
Please help me understand if the question you are asking. Are you searching for general troubleshooting? Is your freezer currently experiencing an issue? With any additional information I would like to further assist you with any troubleshooting steps available. I look forward to hearing back from you. -Matt
Sep 25, 2014 | Frigidaire Freezers
Where are the cooling lines for a frigidaire chest freezer model#GLFC2027FW6?
they run around the entire perimeter... Just put something heavy on the top of it.
Aug 09, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Frigidaire fre196a
I would check to see if the compressor is running. If it is very hot and not humming then the comp is done for. or very hot and you can feel it running constantly the you have a leak and note enough refrigerant. If you hear it run then click then run then click and if hot the comp is done for and needs to be replaced.
Apr 01, 2014 | Freezers
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
Frigidaire refrigerator compressor overheated when I left the door opne.
the motor of the compressor may have tripped on overload protection. Allow it to cool down and then unplug the fridge then plug it back in and try to run it. It should run. Be advised that the condenser coils underneath need to be clean. You should have a strong person tilt the empty fridge while you vacuum and clean all the dust and lint off the coils. Be gentle as these coils are fragile and are easily damaged. Hope this helps.
Mar 26, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
I own a frigidaire model # CF-5D-L*2 manufactured in Feb. 1987 and it stopped cooling off. I've looked at the underside of it and don't see anything off the bat that would be wrong with it. Can you...
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
Good luck.
Sep 13, 2011 | Frigidaire Freezers
Frigidaire 20 cu ft. upright freezer went out a few days ago. Discovered bottom seal was not in place but fixed that. Alarm light stayed on through the night and freezer is not cooling AT ALL although...
Is your compressor kicking on? If not then check the contactor-relay and the capacitor. If that isn't the problem then it is probably your compressor. Which is quite expensive to replace.
Aug 08, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Brand New Freezer, won't cool
You did nothing wrong. I believe it was faulty at the time of purchase. Return for refund
Oct 21, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Logo
756 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
