I brought the saw to a local (and reputable) chain saw repair shop and he told me he couldn't get specialty parts (like retaining bolts) and if he could, it would be an extensive job.
Do you know where I can find these bolts? I can do the replacing myself.
Even a parts number may help.
Thanks Much!
Keith Matson
Upper Peninsula, Michigan
This weekend I picked up a 14" McCulloch chain saw and have had a hell of a
time getting it started. I am no novice at this as I already have a gas
trimmer and blower. I am sure my fuel mixture is right and have done just
about everything else by the book. In how many pulls do I consistently start
a cold McCulloch chain saw. I should mention that I HAVE started it but can't
believe it should be this hard."
I had the same problem with mine!
If yours is like mine , it has a throttle latch knob to use during
starting. Mine never worked. After pulling myself silly trying to start
it, I just decided to hold the throttle trigger open manually and it
starts every time very easily.
You may want to give it a try if you haven't tried it already.
Thanks...
Call 1-800-521-8559 select parts department , ask them to email you a owners manual, takes about 1 hour and it's FREE
The McCulloch download site is often buggy and does not work thats why
it is better to call them to have it emailed to you direct. Again, it
is free.
or check this PDF...
Hope this will help you...
Thanks
I have a McCullough Eager ****** 2014 Chain Saw.
I broke one the bar retaining bolts (there are two) .
I need a part number (or an expanded schematic) for the bolt so I can find one.
I can replace it myself.
