Question about Troy Bilt 5.5hp Self Propelled Mower
Lawnmower dosent bag grass correctly(leaves clumps of grass behind) also doesnt seem to have the power it once did.Not sure whats up.
  • John C Bridgers Sr May 11, 2010
    Hello sjksov:
    >>Does the Engine Seem to be Turning/Reving the Same as it Usually Does or is it Slower?
    >>Is the Blade Sharp and the Lift (Upturned Area Behind the Sharpened Area) in Good Condition (not Worn Down or Bent)?
    >>Is the Underside of the Deck Clean and Fairly Smooth?
    >>Is the Blade Tight?
    >>Is the Blade Adapter (If applicable)being Held Correctly by the Shaft Key?
    Thanks.
    Respectfully
    jbridger (John)
  • Anonymous Mar 24, 2014
    It leaves a line of grass behind it!
There is a little do dad that fits in the hole that the grass is suppose to come out of called the rear mulching baffle that blocks the hole to the bag... remove it and shuld be ok
Posted on May 14, 2009
Troy Bilt self propelled walk behind...grass goes everywhere!!
Mine works,great,take bag off and it will mulch it and look like it's being bagged up.Is your grass knee high?Do you have it low enough?Here's your manual,read the part on grass catcher and see if your doing something wrong,make sure grass door is open.Check your blade to make sure they didn't put it on upside down.The cut part should be facing out. http://pdf.lowes.com/operatingguides/043033566280_oper.pdf
Jul 21, 2017 | Troy Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
Aug 31, 2014 | Garden
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
Lawn mower wont pick up the clippings
if you have ever mowed your lawn when it was wet, you might have formed a clog in the pipes to the clipping catcher. Make sure that the mower is OFF (so you don't chop off your hands) and take a look at the bottom of the mower -- if there is a lot of grass stuck there, you probably have a clog. Clean out the grass from the bottom of the mower, and remove the bag. Make sure that the opening from the base of the lawnmower to the bag is totally clear and give it another shot.
If it is not this, are the clippings just clumping up on the ground as you mow the lawn? or are they being thrown around the yard like they have no direction as to where to go?
If the connection between the mower and the bag are clear, and the grass is just clumping as you cut it, there might be some sort of blockage that you did not notice, keeping the clippings from going where they are supposed to. Make sure you have your bag hooked up properly, and that the clippings have a clear path to the bag. If there is still no love on it, you will probably have to see a repair professional so they can give it a good look (it's tough to resolve complex issues over the internet).
If the grass is not clumping when cut, but is being tossed in all directions instead of being directed to the bag, then you will have to take it in for service -- this would seem to indicate that the mower blades have somehow become distorted and the air flow that you need (to direct the clippings) is not being directed properly. A professional repair person would have to have a chance to see the mower in action to find out what is wrong (once again, it's difficult to fix something you can't see). Good luck ... hopefully it's just a clog (it happens to me all the time).
May 29, 2011 | Toro Power Lawn Mower
I have a single cylinder Ranch King riding lawn mower. Model # 133K6796205. Bought in 1993. I need to know what type of oil to put in it? I am also having a problem with the grass collector. Even if...
Hello You can use straight 30 w oil most engine manufactures agree for summer equipment now for winter where it gets cold like in a snow blower the request you to use 5-W30. As far as your grass collector check your blades #1 to see if they are the correct blades for that mower. #2 yes the engine will overheat as the clumped of grass will slow down the blades causing more load on the engine.This is not a uncommon problem wet or damp grass will clump up even if you do not have a grass collector,it will stick under the deck again causing problems.Hopefully this helps.
Thanks Ben
May 02, 2011 | Garden
Clippings not going into catcher...dropping onto lawn
ck the outlet of the deck and any connection between the deck and bag for debis build up.
Sep 13, 2009 | Garden
Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Toro Lawn Mower With Toro Power Tools
Troy Bilt 5.5hp Self Propelled Mower Logo
653 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
