Question about Sony Ericsson W550i Cellular Phone
Blank screen after using data cable on pc i have some how reversed all the data and have been left with a blank screen
  • 36 Answers
What do you mean by blank screen
white screen ?
reload the softwere.
Posted on Oct 14, 2007
MS 2285 screen is intrermittantly blank
Yes the screen data connection wires run past the left side hinge. Over time the wires, due to flexing wear through to some degree.
This data bus should be replaced as soon as possible. If a short occurs then it can damage the pc or the screen.
A pc technician will be able to fix it.
Take care!
damnor01
Jun 06, 2012 | Gateway Computers & Internet
When i start my computer , i see a blank screen and a dash is blinking on the upper left hand corner. i am not able to do anything besides (F12) boot system
just open the right side cover of your pc and unplug the powercable of harddisk and plug the otherone or same and then try again. chek all your data cables too.
Apr 19, 2011 | Computers & Internet
There is a white blank screen when i turn on
A white blank screen usually means that there is no data reaching the LCD. This can be caused by a bad video card, bad cable, or bad LCD. Rarely, the cable is just unplugged on either the back of the LCD or on the system board (or video card if separate).
Apr 25, 2010 | Computers & Internet
Unable to transfer photos from memeory card with usb cord
uninstall fuji software from laptop. plug in data cable, pc will ask u for drivers then load it. if not then pause antivirus for while then use data cable
Jun 18, 2009 | Fuji FinePix Z10fd Digital Camera
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
Blank white screen
yes on emma III site but you need authorused passord for this
sony ericsson not allow me for this try to your end.
Oct 14, 2007 | Sony Ericsson W550i Cellular Phone
W550i sony erickson white screen
after using the data cable i have revesed all the data on my phone and am left with a blank white screen that wont switch off
Sep 02, 2007 | Sony Ericsson W550i Cellular Phone
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Reverse KVM problems
If you are sure the left monitor?s power is not the source of the problem it does sound like a shielding or excessive signal loss in a device/cable. If it?s always the left monitor I would try unplugging the video cable that goes from the left monitor and plug it into the right monitor; do the same with the other monitor. If the problem moves to the right monitor then that eliminates the monitors and we move on. If the problem goes away then probably one monitor had more signal degradation than the other. If the problem stays then the monitor is the source of the problem. If the problem followed the cable then I would exchange the cables that run from the switch to the monitors; if nothing changes exchange the cables that run from the switch to the PCs. If exchanging any of these cables results in the problem moving then you have a damaged cable or a bad connection. If the problem is still on the left monitor unplug the cables from the left PC that run from it to the switch and plug them into the right PC; do the same to the right PC. If the problem moves then you might have a damaged switch OR perhaps the video card output on one of the PCs is weaker than the other. All cables and devices weaken the video signal to some degree but the amounts can differ wildly. Over the years I?ve had this problem caused by cables, switchboxes, video cards, radio transmitters, bent connector pins, poor connections, excessive cable lengths, monitors and accumulative signal loss from several devices. The last is the hardest to diagnose. Good luck and let us know what happens.
Jan 01, 2007 | APC Cables - KVM Products, Data Switches,...
Sony Ericsson W550i Cellular Phone Logo
170 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
