Question about Maytag Dryers
My maytag electric dryer won't heat on all cycles
I suspect that it may be the timer not closing a contact that turns the heating element on.
  • tradergator2 May 13, 2009
    It does heat. Just not on all settings.
  • 286 Answers
My advise is to check your heating element to see if its open. You might have a break in the element
Posted on May 13, 2009
  • Rich Wright May 13, 2009
    ok does it heat in time cycle or auto. it could be thermostat(sensors) that could cause this. The wiring is different depending on which cycle was used. Sensors cost very little compaired to a timer. It might be a timer but I would look at the sensors first
Maytag atlantis dryer wont shut off. changed the timer and it still wont move.
send the model number.if this is electric try this.put it on air fluff and start it,if it has heat your element is bad,it's grounding out,part of the element is touching the metal case around the element.if it just did this on auto i would say change the cycling thermostat but on timed dry it just counts down like a clock.i saw this once and the element was bad,grounding out.it was tricky i thought it was the timer also.
Nov 27, 2017 | Maytag Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
I have a Maytag electric dryer, m/n LDE9206ADE. It has no heat, but heater element has continuity. What do I check next? Thanks.
Check the limits on the heater chamber for continuity. If all are fine and the power going into the dryer is fine then the timer is suspect. Find the ower wire from timer to element and check for continuity between that terminal of the timer and all other terminals of the timer while roating the timer to various positions.
If that meter cannot get a read then your timer has a bad terminal(burnt contact)
Mar 05, 2011 | Maytag Dryers
Has power but does not turn on.
I assume it runs and this is from that stance. If it doesn't the motor has to be checked and the power coming in. In fact the dryer can run and still not have the correct power to opperate the heater.
A dryer has to have 2 things to dry clothes. 1 Air supply and exhaust, 2 Heating source. No mater if its a gas dryer or electric these 2 items are what dry the clothes..
A. If the dryer has all of these things it has to be heating and an air flow problem (kinked or dirty dryer duck, motor fan clogged with lint, vent flapper not opening...) is suspect.
B. ELECTRICAL
Assuming you have a volt meter and know how to use it properly.
These are the steps that the power and machine have to take to operate properly
1. power is correct (USA 220V across line and 115v to ground/neut) 2 hot lines with potential between them and a neutral and possible a ground
2 Door switch is closed
3 Timer switch closes and ready s power to heating element through centrifugal switch in the motor circuit after the motor is running.
4 the heating element is assumed to be good and have 220v at this point. Checking for voltage at the element will assure all before are ok and at least allowing the heater to work.
5 the heating element is controlled by 1 or more thermostats and a safety thermostat. If either of these switches do not close when the dryer is "cool" they are bad. NOTE some dryers could ahve 3 wire thermostats. These can read closed on one set and open on the other. And this is how they should be if good. But tracing the wire diagram will tell which set is closed and when.
6 if you have power, the timer contacts to the motor and the heater (separate circuits usually)are "closed", the motor runs, the cent switch "closes", the temperature operating thermostats are closed, and the heating element is good you have to have heat.
1 Check for 220V power into the dryer. If not check breakers and turn off and on several time pushing them firmly. If this is ok and 220V present step 1 is done. proceed through all steps above.
If these instructions and explanations are foreign to you I recommend you contact a local service person to check the appliance for you. There are several reasons but mostly safety. DO NOT ASSUME THE POWER IS EVER OFF. Like an unloaded gun is the only one ever in an accident, same applies to electric. The only time anyone gets hurt by electric is when the power is off. If the plug isnt in your hands and you cant see the knives its assumed hot til checked. even with a breaker thrown still check it.
Nov 01, 2010 | Maytag PYE2300AY Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Keeps heating on cooldown
needs new timer switch
the timer swithc contains 2 switches one for the motor and one for the heating element, the element switch has fused closed. not reliably repairable,
even if open the timer, break apart the contacts, file them smooth, reassemble, will still lock up again
replacement is less than a new dryer
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
