Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Printer wont do anything
I had an employee try to fax too many pages through the feeder, so now the printer turns on and the alarm light turns on and refuses to copy, scan fax or even print... ive tried refilling the paper as well as replacing the ink cartaridges yet nothing. any help would be greatly appreciated.
    Champion:
  • 214 Answers
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it
Posted on May 14, 2009
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
My printer is a Canon Pixma MX340 it is showing a error Document in ADF Press [ok] but after pressing ok another error reads Close the feeder cover [ok] eject the document
I had the exact same problem. The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". Even after I placed paper in the ADF and the paper would feed the document through it, the error and the Alarm light was still there. I found the solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution to a damn annoying issue.
Sep 04, 2010 | Canon PIXMA MX340 Wireless Office...
Lines on Outgoing Faxes and Copies from Feeder Is there a way to clean the doc feeder scanner? I have a big line going down the center of the page when I copy or fax from there. Thanks!
If you lift the top of the unit so that you can see the scanner glass and clean the surface on the left side and the very end of the scanner you should be ok. The sheet feeder runs the pages through the feeder and down to the glass at the end then back to the feeder and out to the stack of pages. If you try to scan anything with wet ink, highlighter, marker, etc some may come off on the glass and cause the lines to appear. Just use windows on a paper towel, not sprayed on the unit.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
The automatic-feeder does not work. Everytime I
There is a small power cable that connects the main printer to the sheetfeeder. It is loose or unplugged.
Look on the back side of the Automatic Feeder, near the top.
Plug it in ... it will work.
Nov 13, 2009 | HP Officejet 7210 All-In-One InkJet...
My Canon Multipass F60's alarm is blinking and message says "Waste Ink near full". What should i do?
My canon c530 multipass fax machine has the alarm light blinking and wont fax anything. can anyone please help me?
Oct 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Priner wont feed
I will recommend that you put your printer power off for 2 seconds and remove the tray again and reset it back accordingly and put the power on again and try to fax. Make sure you turn. Let me know how it went.
Jun 18, 2009 | Canon imageCLASS D780 All-In-One Laser...
Hp 6210 won't print or read anything that goes through top feeder
The scanner unit is not coming to the home position for the ADF, you can't get individual parts.
Mar 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
Faxing multiple pages
Faxing using the scanner glass, it would ONLY allow you to do it one at a time. You can Use the Automatic DOcument Feeder on the TOP part of your printer. load all those pages and try to do the faxing. That should work.
Please, let me know if the issue is resolve.
Thank you so much.
adonscott
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
99 people viewed this question
old marine
old marine
