Question about Alpine MRD-M1000 Car Audio Amplifier
Car amp turned off in middle of play
I was listening to my music and I turned up the volume. Then my speakers made a scratchy sound and the amp turned off. I cant get the amp to turn back on and my reciever is working. What could be the problem? I hope I didnt kill the amp. I dont a fuse connected to the hot wire (yellow) which is connected to the amp. Maybe too much power from the battery went to the amp and blew it? Maybe the amps 2 fuses blew?
  • 4 Answers
Check all fuses and connections first. Without a fuse you may have got a power spike and it could have killed your amp.Make sure your default protection aint cutting your amp off.
Posted on May 19, 2009
  • 56 Answers
Make sure and check all the fuses including the one under hood also check all wires to see if they are well connected
Posted on May 13, 2009
Blown/scratchy speaker
Based upon your brief description, it sounds like the internal speaker itself has worn out (likely cause) or possibly the internal speaker wire(s) may become disconnected or may be shorting out.
LeapFrog has discontinued product support of our "Learn & Groove" Musical Table with green legs that was made in 2010. LeapFrog Customer Service declined to discuss replacement parts, so I searched eBay for an exact speaker replacement.
BTW, I am not affiliated in any way with the eBay seller nor do I work for LeapFrog... I'm a Computer Engineer/Geek in Cincinnati, Oh trying to solve a simple toy problem. All opinions expressed are solely my own and do represent any technical guidance from the original equipment manufacturer.
Correct replacement speakers are available on eBay and ship from Hong Kong... I just bought qty2 of these speakers for $5.69 total inc s/h/p (only 1 was needed). Delivery time was slow, but well worth the wait...
When the replacement speakers arrived, I had to take off the back panel screws and unsolder the original speaker, so I could resolder in the single replacement speaker under the 2" black cover. The "Learn & Groove" Musical Table speaker now works great!
Some forum posts say that resoldering a computer modem speaker (16ohm .25w) could be used, but this is a temporary solution at best. The replacement speaker from Hong Kong produces a better quality sound and more sound volume when used with the "Learn & Groove" Musical Table.
The speaker replacement specs for the LeapFrog "Learn & Groove" Musical Table with Green Legs are as follows:
"Round Aluminum Shell Magnetic Type Slim Speaker Horn"
.25 watt
Resistance 16 Ohm
Type Internal Magnetic, Slim
Shape Round
Bottom Diameter 20mm/ 0.8"
Outer Diameter 35mm/ 1.4"
Height 9mm/ 0.35"
Material Aluminum, Metal, Plastic
This replacement speaker worked great for me and now my Granddaughter can again enjoy her toy that I was able to fix!
Mar 23, 2014 | LeapFrog Learn and Groove Musical Table
SET A RINGTONE & PLAY MUSIC
u need to change the phone sound ic or change the phone speaker.
Feb 13, 2012 | Samsung B3310 Cell Phone
My amp becomes distorted when I turn my keyboard up. Both the Master Volume and the CH1 volume knobs are in the middle(12 o'clock). How do I keep my amp from distorting?
You left off the one bit of info we need... however, make sure the volume control on the keyboard is around the halfway point... If it is way down, turn it up and reduce the channel volume knob some. Make sure the cable from the keyboard is an instrument rated interconnect and not one intended for speaker (usually marked as such). Make sure the keyboard AND this amp are powered from the SAME receptacle... even if you have to run an extension cord. Listen with headphones on your keyboard to make sure the sound is clean there.
Sep 01, 2011 | Roland Elektronische Musikinstrumente...
I listen to my iphone on my Logitech speakers on my desk. When the volume is low, the speakers work great. However, when I turn up the volume, the green light fades, and the speakers are scratchy. Is...
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Jun 16, 2011 | Logitech LS11 2 Speakers
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Making scratchy sounds through speakers when music is playing
The speakers inside it have aged and their membranes have become weak and they crumple under the load. Unfixable - either listen to a much lower volume or get new ones.
Aug 25, 2010 | Skull Candy Rasta Stereo DJ Headphones -...
My speakers make almost no sound at max volume. However if you listen closely, the music still plays, its just not amplified. How can i check the amplifier?
if you are wanting bass adjust your amp settings to low pass. if you are wanting a lil bass- a lil treb- adjust your amp to full. and make sure your rca cables are hooked up in the proper spots.
Feb 08, 2010 | Car Audio & Video
When i turn the volume up past a certain point the music stops playing and all i hear is a scratchy noise every couple seconds
This is usually due to the headphones or speakers not being able to play back the audio past that point, try a different set of headphones, the earbuds might be burnt out. some earbuds **** and cant play sounds past a certain dB the general dB levels tolerated without distortion are about 104-110 ish, but if you are listening anywhere near that your gonna hurt your ears. tests have shown that audio levels past about 90dB will seriously damage your ears after prolonged usage. Generally get nice in-ear ear buds with noise cancelation and never move your audio past 90% to clearly hear the music without damaging your ears.
I got my girlfriend some Jbuds J2 and they are great and i prefer them over my 200$ bose ear buds. check amazon they are about 14$ the J3's are around 24$
Nov 04, 2009 | SanDisk Audio Players & Recorders
Scratchy Sound, Major Problem
Try the speakers on another PC with good working sound. This will indicate either a speaker problem or a sound card issue.
If speakers work ok on 2nd pc, then you have a sound card issue on your pc. If speakers are still scratchy on 2nd pc.. check the metal connector end, make sure it is clean and shiny. If there is any rust or other oxidation, clean it off with a very fine grade of sand paper
Apr 28, 2008 | Logitech X-530 Computer Speakers
Alpine MRD-M1000 Car Audio Amplifier Logo
131 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
