Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
The line keeps feeding back inside the trimmer head. How do I open it or get the line out even when bumping doesn't work?
  • 41 Answers
On bottom of trmmer head it should have a knob or two taps that push in. Look on spooler there is an arrow that tells you which way to spool string.
Posted on May 13, 2009
Echo SRM225 line trimmer continually feeds line
If the line feeds with out bumping it nay be the line gas been put on the wrong way
Apr 30, 2017 | Echo Garden
We're having trouble with our just-purchased Husqvarna 128CD trimmer - the tap head doesn't seem to work properly. When I tap the head, the line doesn't extend. On first use, the line became...
It is a fairly simple head, push the two ears in either side of the head, the black base will then come off, check the cord inside has not become trapped, check the blue button depresses ok, re assemble, run the machine at full revs and bump it down on the grass.
Jul 09, 2011 | Husqvarna Garden
Husqvarna makes a trimmer that you don;t bump the head to feed the line, right?
What make you ask this question?
just check this out, it replaces the orig. head and all of Husq. have bumps unless you change it..
Tanaka head semi auto.
Nov 05, 2010 | Husqvarna 28cc Gas Line Trimmer
While trimmed is in use, how do I release more trimmer line?
Bumping the string head lightly on the ground will release more trimmer line if the line was loaded properly and spooled in the correct direction. If the line was loaded wrong, doing this procedure won't help. Make sure your line was loaded correctly. Do this bump as the engine is slowing down or running slow. Most all gas trimmers work this way, but some of the electric ones have automatic line feed and no bumping is necessary.
Oct 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Line doesn,t feed automaticly
The line may be on backwards or has developed a knot. Debris may have worked its way inside the bump head preventing it from functioning.
Check out these items.
Best regards
Mike
Aug 20, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Automatic line feed???????
I would take off the head and have the spring replaced that keeps the button down when using.
Aug 30, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Echo trimmer with bump feed is not feeding
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Jul 30, 2009 | Echo Garden
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
336 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
