1990 honda shadow 1100 sometimes difficult to get to 2nd gear
SOURCE: 2005 honda shadow spirit 1100. runs with choke on
Have you tried to adjust the tickover screw on the carbs?
SOURCE: Do I use regular or premium gas for my '96 Honda VT 1100 C Shadow
You always want to use the highest octane gas u can find in a motorcycle engine .... 91 at least
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
SOURCE: stator removal honda
There is a tool that is used, it looks like a steering wheel puller or flywheel puller. Loosen the nut, a strap tool is handing to hold the stator still while you loosen the nut. Then using the removal tool, you pull this off. reassemble by tighting the nut. You should be able to get a puller at autozone in the loan a tool program. I hope this helps
SOURCE: need the 88 honda shadow 1100 service manual
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Go to this site
and you can download a free PDF service manual and Haynes workshop manual. The "owners manual is not listed. The site may
take up to 20 seconds to load the complete list of manuals. www.carlsalter.com/motorcycle-manuals.asp Most all of the manuals are in English but some are not.
There is no way to be sure without doing the download. You can always delete it
if in a foreign language.
Go to the site
below where you can see a parts diagram for your specific bike. You will select
the actual brand, year, model, etc., once you go to the site. Part numbers and
prices are also shown. You can order parts from this site. In the event no
price is shown on a particular part and/or the notation "Not
Available" is in the description, the part is not in stock. Please rate my answer. Thanks!
www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
Testimonial: "Thank you very much, I downloaded the service manual, but I could not find the owner's manual. Thanks again, Great help"
