Question about Samsung HCL552W 55" Rear Projection Television
I have 47 inch with double color in picture, reds and green
I just turned the set on and there is a red line at the top of the screen and double coloring in the picture.
I have a sloping red line across the top of the screen and when the picture is displayed the red and bule hues are not aligned giving a double image
Posted on Aug 31, 2008
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Posted on Jan 09, 2008
I own a Panasonic HDTV projection monitor PT-47WX42C I am having convergence/warping issues; There is a large green/red curve in the bottom rear of screen about 4 inches tall, and stretching over more...
Replace the convergence ICs they will be big black ICs and will have Part number on them example STK392-110
Mats Electronics has them for 9.95 each you will need 2 .
1-800-628-1118
Sep 10, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Double vision lines of red and green
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 12, 2009 | Samsung HC-P4752W 47" Rear Projection...
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Rear screen projection tv
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Jun 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Samsung HCL552W 55" Rear Projection Television Logo
337 people viewed this question
Jerry Greenberg
Jerry Greenberg
