Question about Brother MFC 210C All-In-One InkJet Printer
Fax machine I can't get the display on my fax machine to read 'F/T' instead of 'MAN'. I have pushed the help botton, and followed the instructions that the machine printed out, but alas, to no avail. What am I doing wrong?
  • 832 Answers
Press fax button (green light on) then menu then 0 then 1. press the arrow-up button til you can read fax/tel in the display press menu. To leave the programming press stopp.
Posted on Oct 14, 2007
How to get meter read for konica magicolor2490
Push the Display button
This will show the toner levels.
Push the down arrow to toggle through the copy counts (B/W & colour, copies, faxes, scans etc).
If you are looking for the instructions in a PDF manual search for "counter" instead of "meter".
Jan 10, 2014 | Konica Minolta magicolor 2490MF Laser...
Stuck on manual recieve
Press the RECEIVE MODE button on the panel until the display reads FAX on the right side.
Jun 18, 2007 | Brother FAX-575 Plain Paper Thermal
We a incoming fax comming, we don't get fax but fax call report with "comm error 392"
Assuming you have an HP laserjet, you can either try again in a little bit or disable v.34 on your machine and use v.17 instead
Perform the following to turn V.34 off and access the lower speed of the local machine.
1. Press the ENTER/MENU button one time.
2. Press the or > button until the front display reads "Fax Setup".
3. Press the ENTER/MENU button.
4. Press the or > button until the front display reads "All Faxes".
5. Press the ENTER/MENU button.
6. Press the or > button until the front display reads "V.34".
7. Press the ENTER/MENU button.
8. Press the button until the front display reads "Off" and then press the ENTER/MENU button to save the setting.
Feb 28, 2011 | Office Equipment & Supplies
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Drum error message
check the silver spring loaded contacts inside the drum cavity make sure they casn be pushed in and spring back out. Also clea them with a dry cotton swab
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine cuts into incoming calls
Issue: Device answers while in Tel Priority Mode
Solution: Disable the Manual /Auto Switch MX700
Man/Auto Switch By default, [Man/Auto Switch] is set [OFF]. If it was set [ON] and you want to change this setting or if you want to increase the time before the fax answers, follow these steps.
1. Press the <FAX> button, then press the <Menu> button . The Fax menu is displayed.
2. Press the l_mark_s.jpg or r_mark_s.jpg button to select Maintenance/settings
, then press the OK
l_01815.jpg The Maintenance/settings screen is displayed.
3. Press the l_mark_s.jpg or r_mark_s.jpg button to select Device settings, then press the OK button.
l_01918.jpg The Device settings screen is displayed.
4. Press the t_mark_s.jpg or d_mark_s.jpg button to select FAX settings, then press the OK button.
l_02021.jpg The FAX settings screen is displayed.
5. Press the t_mark_s.jpg or d_mark_s.jpg button to select RX settings, then press the OK button.
6. Press the t_mark_s.jpg or d_mark_s.jpg button to select [Manual / auto switch], then press the OK button.
7. Press the t_mark_s.jpg or d_mark_s.jpg button to select [ON] or [OFF], then press the OK button.
from canon website
Dec 19, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Fax ready call service
By now this may be a mute point given the time differential ....however;.
if the machine is saying"please call service" do the following..
Press Prog,*,6 ..then press the right arrow key until "service call" appears in the lcd then press ENTER.
aAt this time the display will show the error...favorite was "heater error"
Press STOP to exit.
**If heater error is displayed,you will need a service man to replace the fusing unit in the machine.
Dec 16, 2008 | Muratec F320 Plain Paper LED Fax
HI, I have a Xerox DC240 that has an error code 093-317 and I need to get a job out tonight. Can any one help.
Try replacing the Xerographic Module, if that doesnt work then the donor roll in the developer housing is bad.
Aug 04, 2008 | Xerox Office Equipment & Supplies
F-60 Muratec Fax Machine
try the following..Press PROGRAM,#, ....REPEAT until the desired language is displayed.
You can still download the operators manual from Muratecs web site... just look under "Legacy" fax machines.
Mar 26, 2008 | Muratec F160 Fax Machines
Brother Intellifax 3550
Try unpugging it and waiting half hour then plug back in.
Feb 15, 2008 | Brother IntelliFAX 3750 Plain Paper Laser...
Brother MFC 210C All-In-One InkJet Printer Logo
32 people viewed this question
James Cagle
James Cagle
Jim Keysor
