Question about Microsoft Windows XP Professional
I need license update for Cookie Guarder, Secure Channel, Surf Protector and Registry Doctor which are turned off. My PC system works with Windows XP professional
  • Anonymous Mar 14, 2014
    i used xp from long time so need new update driver, so in used registry reviver but i lost my license code so help me to start reg.reviver. to clean my errors and to run fast my pc
    Problem Solver:
  • 8 Answers
Posted on May 13, 2009
This is problem in my laptop -- Windows Script Host -- Loading script "C:\WINDOWS\:Microsoft Office Update for Windows XP.sys" failed (The filename, directory name, or volume label syntax is incorrect. ).
Microsoft has stopped providing XP users with security updates, forcing them to either upgrade to another, newer operating system, or gamble with their safety. While the latest usage figures show that a large portion of users are moving away from XP, there's still a sizable number of users who aren't -- or can't.
If you're an XP user, or know some XP users, there's a trick which makes it possible to receive security updates for the aging OS for another five years -- right up until April 2019.
The workaround makes use of updates for Windows Embedded Industry (formerly known as Windows Embedded POSReady). This is based on Windows XP Service Pack 3, and the security updates which are being released for it are essentially the same ones Microsoft would have pushed out for XP, if it was still doing so.
You can't simply install the updates -- that would be too easy -- and you'll receive a version mismatch error if you try. But a simple registry tweak is enough to fix that.
Create a text document, and call it XP.reg. You'll need to make sure .reg is the proper extension -- so not "XP.reg.txt". If it's not showing up as a registry file, open any folder, go to Tools > Folder Options, select View and uncheck 'Show hidden files and folders'. That should fix the problem.
Right-click the file, and select Edit. Paste in the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\PosReady]
"Installed"=dword:00000001Save it, and then double-click the file. That will make that change to the registry. That's all you need to do. Windows will now automatically fetch updates designed for POSReady 2009, ensuring XP remains protected for the foreseeable future.
This trick only works for 32-bit editions of XP, but there's a workaround for 64-bit versionshere.
Naturally, there's no way of knowing how long this trick will work -- Microsoft could put a stop to it at any moment. Also, because you're installing updates for a system other than Windows XP, there's the possibility that not all updates will work as intended. But it's still worth a shot.
Apr 04, 2013 | Acer Computers & Internet
Tip
Change the volume licensing product key on a Windows XP SP1-Based Computer
Because of changes in Windows XP Service Pack 1 (SP1), Windows XP-based computers that use a leaked product key that is known to be available to the general public may not be able to install SP1 or automatically obtain updates from the Windows Update Web site. For an easy and quick method of obtaining your own CD Key please read Quickly Retrieve Windows CD Key
If you have only a few volume licensing product keys to change, you can use the Activation Wizard.
Warning!
This document contains instructions for editing the registry. If you make any error while editing the registry, you can potentially cause Windows to fail or be unable to boot, requiring you to reinstall Windows. Edit the registry at your own risk. Always back up the registry before making any changes. If you do not feel comfortable editing the registry, do not attempt these instructions. Instead, seek the help of a trained computer specialist.
Note: Microsoft recommends that you run System Restore to create a new restore point before you complete the following steps:
  1. Click Start, and then click Run.
  2. In the Open box, type Regedit, and then click OK.
  3. In the left pane, locate and then click the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents
  4. In the right pane, right-click OOBETimer, and then click Modify.
  5. Change at least one digit of this value to deactivate Windows.
  6. Click Start, and then click Run.
  7. In the Open box, type the following command, and then click OK. %systemroot%\system32\oobe\msoobe.exe /a
  8. Click Yes, I want to telephone a customer service representative to activate Windows, and then click Next.
  9. Click Change Product key.
  10. Type the new product key in the New key boxes, and then click Update. If you are returned to the previous window, click Remind me later, and then restart the computer.
  11. Repeat steps 6 and 7 to verify that Windows is activated. You receive the following message:Windows is already activated. Click OK to exit.
  12. Click OK.
  13. Install SP1 for Windows XP.
If you cannot restart Windows after you install SP1, press F8 when you restart the computer, select Last Known Good Configuration, and then repeat this procedure.
on Apr 25, 2010 | Microsoft Windows XP Professional for PC
How fixe victim genuine software windows XP
you need to buy license and there is another solution as well to disable the genuine in registry.
Aug 19, 2011 | Microsoft Windows XP Professional for PC
My computer security updates fails all the time with numerous codes: Security Update for Windows XP (KB2555917) Security Update for Windows XP (KB953155) Security Update for Windows XP...
Check this answer at answers.microsoft... it may be as simple as turning off your antivirus while installing these update. You may also try the installation in Safe-mode.
Aug 09, 2011 | Computers & Internet
How to remove software counterfeiting in my desktop? please help!
It is not possible to remove the software counterfeiting message unless you you reinstall the operating system... After reinstalling the windows, turn off automatic updates in your computer and turn OFF synchronization with windows time server. That will help...
But you have to completely erase and reinstall the operating system on your computer and before connecting it to the internet you have to do all the above settings.
May 20, 2011 | Microsoft Computers & Internet
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
How to get free serial number in any program?
That's hacking. Pls kindly buy a license from microsoft & receive updates to secure your computer
Feb 08, 2010 | Microsoft Windows XP Professional With...
My system is not responding
--- please first of all arrange system setup disk for WinXp
--- Start Windows in safe mode, if yu can, uninstall all undesirable programs, antiviruses, TSRs
--- Restart System
if problem is not solved, please repair windows, by setup & upgrade from the XP installation disk.
Spyware Doctor, Panda are good antiviruses, please update them on internet after first instalation
Zulfikar Ali
Jan 25, 2009 | Microsoft Windows XP Professional
Monitor not working
Use a legitimate serial code to activate your Windows again. This is a built in protection system from Microsoft which simply disable some features to "punish" you for using an illegal version.
Greetings,
DarkNeogen
Jan 25, 2008 | Microsoft Windows XP Professional for PC
Registry disable
Need more information, on the problem.
If your computer is still booting then your registry would still be working. So when you say its disabled, how do you come to that conclusion?
Are you just trying to use regedit? If so i can provide a download. If not just need to know  what message or  program is  giving problems.
Oct 11, 2007 | Compaq MS Windows XP Home Edition for PC
Microsoft Windows XP Professional Logo
207 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
