Question about Epson Stylus Pro 4000 InkJet Printer
Cartridge problems Epson 4000
Good day to you guys,  I have a problem with my Epson 4000 printer. It occured before, but after few intents the problem was solved, but this time it won't do anything. Every time when I run clear nozzles cycle, the printer tells me that there is no ink in several cartridges, but when I unlock and lock cartridges for several times the problem disappears. This time when I finished my clear nozzles cycle, the message of empty cartridges won't go away even if I tried several options ( turn off my printer, unlock and lock cartridges, etc. ). I know that the cartridges are not problem because they are brand new ( bought in B&H a few weeks ago ). I would very appreciate your help, and thanks in advance for your support. Greetings, Nemanja Brankovic Photographer
    Scholar:
  • 117 Answers
Where are you located? is it Humid? possibly the chips on the cartriges have something on them (corrosinon, oil from a finger touching the chip, etc) that is interferring with good contact with the wire "feelers" inside the machine. clean the chip with Qtip and alcohol, or fine fiberglasss bristle battery contaact cleaner (hard to find these days)
Posted on Aug 25, 2009
Why will my Epson wf7620 not print black ink after replacing the cartridge?
Hi. I don't know if your printer is new or old or if this was the first time you replaced the cartridge or this has occurred after several changes. Most if not all printers will have this occur after replacing a cartridge if the ink had been depleted for some time and allowed to dry up in the jets. Sometimes all it takes is a day for this to happen. I have found that I must go through several cleaning cycles to clear the clogged jet(s). So, try doing a few cleaning cycles and see if that solves the problem. Another cause for a printer not printing after replacing a cartridge is surprisingly a FAULTY or remanufactured cartridge. There should be a program on your computer that displays the cartridge condition, cleaning procedure and ink levels. Give that a look over.
Feb 20, 2015 | Epson WorkForce WF-7620 Wireless Color...
Incompatible ink cartridge ho 4500
I have had simlar problems with other brand inks on epson printer a guy in a computer shop were I bought the ink from told me to take the ink out wipe the chip with a clean cloth wipe in one direction, also your ink when new has a piece of thin plastic that now has a small hole in it as you have taken it out from printer put a small piece of sellotape over hole other wise printer will think you are putting old cartridge in again you might need to do this a few times, but bear in mind that this was done with an epson printer but it doe's solve the problem when it crops up from time to time.
Feb 25, 2012 | HP Office Jet 4500 G510n
Epson Workforce 610 had a paper jam. Removed the paper and now it says a printer error has occurred and to power off the unit. After power off and even removal of the power cord. When turning on it...
I had a similar issue. After ordering a new printer and being told by the epson tech that I need to buy a new printer, I attempted once more to fix the printer before giving up on it.
I noticed when starting the printer up, the container that holds the ink cartridges would move all the way to the right, stop, and then the error would occur.
Eventually, I held the cartridge housing up and forward a little when starting the printer. This fixed the problem, as the cartridge housing was able to get past its stuck point and continue on its journey.
Hopefully this helps someone
Oct 13, 2011 | Epson Workforce 610 All-In-One InkJet...
Printer does not recognize the new cartridge, but doe show the old cartridge as being empty so it does recognize that one.
Are you using original Epson Cartridges? if not, that might be your problem. The cartridges have chips in them and the printer might not recognise some imitations. Also, if you have recently done a firmware upgrade on your epson, you will probably never be able to use compatibles again.
Aug 25, 2011 | Epson Stylus Pro 4000 InkJet Printer
My printer gives a message that I should close the cartridge door. I have done this but the message still comes
tell printer model
if problem occur during restting cartridge
then just push cartridge carriage any side and press start button
Jul 18, 2011 | Epson PictureMate InkJet Photo Printer
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have a damaged cartridge chip sensor in my Epson Pro 4000 printer, I have the field repair guide and new sensor, but can't find any info about replacing this sensor- how can I replace it?
Very old question but not a hard job. Watch this video. :http://www.inkjetcarts.us/support/article/epson-pro-4000-7600-9600-ink-bay-csic-sensor-replacement-tutorial-video-115.html
Or, in the field repair guide you can find the info to turn off the sensors. Google "disable ink sensor epson 4000", thats how I found it, I run all my off. DO NOT DO THIS unless you use the clear refill ink carts that let you see the ink level. NEVER let your printer head run dry.
Nov 10, 2010 | Epson Stylus Pro 4000 InkJet Printer
Printers do not recognize yellow cartridges
http://www.fixya.com/support/r3845491-ink_cartridge
Check out there FIRST befoe you get into things too deeply
A lot of common tips that tend to help a lot of people.
Bob
Jul 22, 2010 | Epson Stylus Pro 9600 InkJet Printer
After cleaning cycle ink cartridges are rendered invalid
I've had the same problem over the years and somewhere along the way came across this simple fix: when you get the "invalid ink cartridge" message turn the printer off, wait 10 seconds, turn it back on, when the screen switches from "please wait" back to "invalid ink cartridge" tap the pause button. this will somehow reset the printer and you should be good to go.
Apr 03, 2006 | Epson Stylus Pro 4000 InkJet Printer
Epson Stylus Pro 4000 InkJet Printer Logo
215 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
