Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
There is a sulfur smell everytime I do laundry. We have tried different soaps and we are even in a different house. HELP!
I am noticing the same problem recently! Hope someone can help.
Posted on May 13, 2009
Tupperware smell
store loose baking soda in it for awhile
Dec 01, 2017 | Dishwashers
I own a kitchenaid dishwasher that is only a few months old and I have this horrible smell on my dishes. I have noticed this also on our old dishwasher. What can it be? I have tried putting bleach and...
I suspect your water supply is at fault. Sulfur and iron in the water will cause terrible smells. You may try using an additive like Lemi Shine with your detergent, but it will likely not help much. I would recommend having your water tested....
Kelly
Mar 23, 2011 | KitchenAid Dishwashers
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
Jan 08, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer smells really bad
your smell is comming from over soaping
a front load machine only needs 1 Tblsp of soap
any thing it builds up and rots thus the smell
get a crystal dish soap
1 cup run the machine empty a full cycle
now use trhe proper soap it will clean away
Oct 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
The washer has a very bad odor. I have tried using different soaps, but it still smells bad. The clothes smell "flat"----no odor----but the laundry room is getting to smell harsh. There is nowater outside...
thedrain has sludged up causing partial blockage. soap powders cause this . check the fall on your drainage. Either attempt self cleaning or get a drainage company to investigate.
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
Hey
try following tips:
  1. Check that the drain line is clear
  2. Check the drain hose for kinks or blockages
  3. Check pump for blockages
  4. Check for build up of soap in the outer tub
  5. Check for article of clothing stuck in the outer tub
please rate my suggestion...
May 21, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Mar 12, 2009 | Kenmore 22422 Top Load Washer
2006 Toyota 4Runner Sulfur smell
I noticed going from a Higher Grade gasoline as well as making sure I change my motor oil on a regular basis (3,000-5,000 mi)to solve this problem. When the car isn't driven at a high RPM for a while, and you go to a quick acceleration it causes this smell.
Jul 22, 2008 | 2006 Toyota 4Runner
Moldy Smell
try running about 3 cups of vinegar in your washer and always leave the door open when you are done doing laundry
Dec 10, 2007 | Kenmore Elite 45986 Front Load Washer
I put laundry soap in the dryer by accident
DO NOT pour water down the lint filter of a dryer! This could have catastrophic results. There are live voltages present in a dryer even with the power shut off. You have a blower fan and a motor in the air baffle. Pouring water in there will definitely damage something (if the soap hasn't already). Detergent is a corrosive and will damage anything electrical and any painted surface if left too long. I hate to say it, but you must open the dryer up and remove the air baffle and clean it out thoroughly. Unplug the machine before you attempt. You need to wipe up all the soap residue with rags. You will need to let me know if the dryer has a lint filter on the top of the machine, or in the door before I can suggest how to disassemble. This will make a big difference in the amount of effort required to correct this. Post me back with the info...
Aug 08, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
603 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
