Question about Acer Aspire 5735 Notebook
My wireless is enabled but isn't picking up any network - how can I fix this? Router seems to be fine as can pick up on my i-pod no problem (acer aspire 5735)
    Scholar:
  • 59 Answers
Make sure your in range. If using windows, goto start>run>services.msc (as an administrator) find Wireless Zero Config and make sure it is started or restart it. This should bring up the wireless icon near the clock, right click it and click view wireless networks (on xp). refresh the list and see if your network is displayed.
I'm not sure how the i-pod displays wireless SSID's but you may have your SSID hidden, which would have to be reconfigured on the router or you could go to "change priority of wifi networks" then manually enter the SSID name and connection info and set it as the highest priority. Also if your using other wireless software besides windows. Try going into that program and setting it to use windows wireless zero config service, I've had better luck w/ it over Dlink,Belkin and even Intel's software.
In addition check the driver by right-clicking on "My Computer">manage>device properties under network adapters if you see a yellow exclamation you need to reinstall your driver, A red X would indicate that it is disabled and needs re-enabled.
Posted on May 13, 2009
Hp netbook not picking up wireless network?
Are you sure your hubby is picking up the wireless from his phone or is he just getting a signal from a cell phone tower?
The reason I ask is that once you hit the button to set the router back to the factory default, the wireless on the router is turned off.
You have to go into the router and enable the wireless and give it a SSID (unless you want the Dlink default) and you have to give it a password if you want it secured.
Jun 10, 2012 | Computers & Internet
Router connected fine... not allowing my laptop to pick up wireless signal. not an internet issue as I have connected primary computer via wire and it works fine. need some troubleshooting ideas to...
In your router settings, look for something like "wireless radio" and make sure that is enabled. It sounds like your wireless is disabled.
Or
On your laptop, your wireless card may be disabled. Are you able to scan and locate other wireless networks on your laptop?
Feb 27, 2011 | Computers & Internet
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect ipod touch to linksys router
Use an Ethernet cable to connect a computer to a port on the router.
Access the router's built-in web-interface, and run the "Wireless Networking Setup Wizard", to configure your wireless network,
and pick an SSID and pick a password.
Then, after restarting the router, enable the wireless networking on your iPod Touch, and it should find your SSID. Enter your password, and you will get connected.
Dec 27, 2009 | Linksys Computers & Internet
Wireless security-enabled network
That should be in your router under "wireless", and then "security" Make sure all your devices share and support the security you haver picked. In other words if you pick WPA2, you should prolly pick WPA2/mixed with TKIP/AES, ect. Dont pick WEP unless you have an older card. Its too easy to crack.
Dec 03, 2009 | Edimax BR-6104K Router (br6104k)
Wireless not detected
Are you broadcasting your SSID 'Network ID" If not you won't see a wireless network if "SSID Broadcast" is turned off in the router.
Login to your router config page and enable 'Broadcast SSID"
Nov 22, 2009 | Acer Aspire 3000 Notebook
Cant connect with my mac even though the router seems to work fine.I am picking up the signal and using it on my iphone
You must configure the airport to connect to your router. Make sure to put the network key in. Also make sure that your airport is enabled.
Jun 28, 2009 | Linksys Wireless-G Broadband Router
Problem with Toshiba wireless conection
If you have your router set-up with security enabled, you should try to re-set the router and then go back onto the routers "control panel" and re-setup the security. You can find out the correct way to reset the router and the correct address to enter into the browser to access the routers control panel by going to the router makers website and checking under Support
Feb 20, 2009 | Toshiba Satellite M45-S331 Notebook
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Acer Aspire 3620 wireless disaster
okay......who is your internet provider??? if it is sasktel then they have a very helpful help line that that you can reach them at and their number is 1-800-773-2121. but before you do that....open your wirless conection options thing and then click advanced and then clik the litle square at the top that says let windows configure your wirless stuff (something like that :P) and then it should work...it did for me....but if that doesnt work give sasktel a call and they'll help you fix it :) (its 24/7 support so give em a call whenever :P)
Mar 26, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 5735 Notebook Logo
364 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
