Question about Garden
John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
John Deere 14SB mower with Kawasaki FC150V series engine.
Cannot change engine speed with throttle lever. The speed of the engine does not change regardless of the position of the throttle lever. Cable is fine and linkage does move.
  • Anonymous Mar 16, 2014
    I have a john deere zero radius mower. When I cranked it and mower for one lap all of a sudden the mower quit moving and when I pushed the handles forward or pull back the mower will not move
  • 246 Answers
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
John Deere 14SB mower... can not change the speed, it keep at the same speed..
I believe your model has a cable control going to the transmission. If that cable is broken it would cause this issue. If you buy the replacement cable, you can change it by removing the pulley from the top of the transmission, then removing the 2 bolts that mount the cable underneath that pulley. Not too difficult if you're a good home handyman.
Oct 08, 2013 | John Deere Garden
My 14SB John Deere mower will start but then quits before moving the throttle, changed oil, oil filter, spark plug, new oil, added fuel stabalizer to gax tank. Any ideas???
Hello. You have some winter buildup in your engine. Get a can of starter fluid and a helper. have the helper shoot small squirts of starter fluid into the air filter while you run the mower. In just a couple of minutes the starter fluid will clear your problem. Joe
Apr 25, 2010 | Garden
Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Nov 17, 2009 | Garden
How do we service the blade / brake clutch assembly on John Deere 14SB lawn mower .
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Nov 14, 2009 | Garden
Does the john deere 14sb have a jet in the carb
Should be a Kawasaki engine with a Mikuni carb, and there will be a removable jet in the center post of the carb.
Nov 12, 2009 | Garden
14sb engine running when blade clutch is engaged the lawnmower stalls.
Normally I believe this mower to have a Kawasaki engine, and the main jet and 'pilot air hole' need to be cleaned. You are running a lean condition, and when the blade is engaged, the engine does not have enough fuel to continue the extra load. A small test for this is to engage the blade and the choke at the same time. If the engine has enough fuel to continue running and engage the blade, this confirms the lean fuel condition. Cleaning those jets will solve the issue.
Nov 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 14SB (with Kawasaki FC150V motor). It
sounds like the valve clearences need adjusting they should be set at 0.004 thou you should be able to find an exploded view at pats small engines site.
Aug 09, 2009 | Garden
Valve noise
Hi you can set them to 4 thou it should quiet them down pretty much
Jun 14, 2009 | Garden
Garden Logo
3,775 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
