Question about Desa International CBP20T Wall Mounted Panel Heater
Wmn20a ODORS We had a 6-9,000 BTU unit in the basement of our last house for years w/o problems. The smallest heater I could find after we moved into a different house was this 20,000 BTU unit at Wal-Mart. Installed easily (I have done this before) using 1/2" CSST and a shut-off valve below the unit. Everything works fine, but it produces a fairly strong odor that is NOT gas. no yellow flames, plenty of air, plenty of gas pressure. Any suggestions? Thanks, GN
  • garynonnemac May 13, 2009
    We have only had it installed for two days. Odor does not seem to be going away. Is smells like you are running a Kerosene heater, even with only the pilot lit. The other one we had did not smell like this.
  • Samuel Charles Spriggs May 11, 2010
    How long have you been using it? Could it be that finish residue (like paint, oil) is just burning off -- and after that's done no more odor?
    New Friend:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
How long has the unit been running for? sometimes with these newer heating elements it takes a while to burn off the oils used to make them.
Posted on May 29, 2017
SOURCE: lights, goes out in a minute
a orange-yellow flame means that your not getting enough oxygen to your flame... for every cubic foot of gas you need 24 cubic feet of air to burn
Posted on Jan 30, 2009
  • 53 Answers
get it checked out professionally before it makes a smoking hole in the ground
Posted on Jul 20, 2009
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Posted on Dec 04, 2009
  • 3150 Answers
SOURCE: Martin gas heater with logs flames hot but hard to see.
Hi do you the make and model
Posted on Feb 12, 2010
SOURCE: I have a natural gas infared 30,000 BTU heater
The sir gas is contorled by an opening ajustment where the gas comes out of orfice. (usualy it turns to make smaller or lager opening. More or less air}
Posted on Feb 17, 2010
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
I have a Coleman TG9S Furnance and I noticed that
Hi there should be a fresh air pipe to your basement from outside to bring fresh air in normaly its behind the unit just above the floor , the air intake is taken from the basement as the air from the intake would now be warm to use , does this help you ?
Feb 09, 2010 | Heating & Cooling
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
Heater goes off with the pilotlight had it for 3 years work great rinnai glo-ray reh-23dft-n
Probably the oxygen sensor faulty or lack of ventilation - this is a safety device to prevent carbon monoxide posioning - needs expert attention!
Jan 17, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Error code 12
Error code 12 is a genaric "Flame Failure" code. I suspect that the flame is not hitting the flame sensor or that the sensor is bad. You will need to get to the sensor located on the far left hand side of the unit. If you have the owners manual, it's part #123. Remove it and clean it off. Make sure it is placed back in the heater properly aligned and all the way in. Then try and light it. If it does not stay lit, it may need to be replaced but check out the burner tray for debris not allowing the flame to travel all the way to the sensor. You will have to remove many parts to get to the burner assembly.
Jan 05, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Desa International CBP20T Wall Mounted Panel Heater Logo
87 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
