Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Installation of printer will not work with my laptop
Is there a specific USB cable for each printer model because when I try to plug in my printer to my new laptop and Windows tries to help me install, it seems to want to search for an older model(DX 8400). My printer is the DX 8450. On downloading an application from the epson homepage it says that the easy print module is successfully installed but still no printer found by the computer when printing. HELP ME PLEASE!
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-30
Posted on Sep 04, 2009
  • 431 Answers
No but your problem might be you are depending on windows to supply the driver ?.
It will keep suggesting the Dx8400 if that is the latest one in its data base for that series I suspect you are running Xp and do not have the driver update facility afforded to vista users .. try this and good luck
http://www.epsom.co.uk/Printers-and-All-In-Ones/Inkjet/Epsom-Stylus-DX8450/drivers-Support
Posted on May 13, 2009
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
Won't print, even when USB cable is plugged in
Do a BIOS update and than do a fresh installation of the printer.
Jul 10, 2010 | Lexmark X4650 InkJet Printer
My brother mfc 5840cn won't install on my new laptop which has windows 7 my old laptop was xp
Brother has not released a printer driver specifically for Windows 7 and this model. You can however use a basic printer driver if the Windows Update feature of your operating system is set to "automatic:"
To set Windows Update to automatic, perform the following: (if you know it already is set to automatic, you may skip these steps)
1) Click "Windows Icon" (Start button) on taskbar
2) From the "Search Programs and Files" box type "change device installation" and start search
3) Click "Change device installation settings" - the Device Installation Settings window opens
4) If it is not already selected, select "Yes, do this automatically (recommended)"
5) Click "Save changes"
Now you are ready to have Windows search for and install the generic printer driver for your model. Your computer must be connected to the internet in order to complete this installation.
Note: If you have previously connected the USB cable, disconnect it from the computer and printer for now.
1) Power on your printer
2) Now connect the USB cable to the back of the printer, then to a USB port on the back of your computer (not to a USB hub or keyboard port)
3) Windows should now automatically search for and install the latest driver for your printer.
4) The "Your devices are ready to use" message may come up on your screen upon completion. You may have to click "Close [X]" to close this window.
You should now have a basic driver installed for your model of printer.
Jan 22, 2010 | Brother MFC-5840CN All-In-One InkJet...
During installation, device is not detected error appears. tried uninstalling software, unplugging cables, restarting, reinstalling, then plugging cables in. did not work. Windows XP o/s. already checked...
is it wireless or usb, if it usb, dont connect the usb cable. on the installation window where it asks for the usb cable, chek mark on the option connect printer later and continue with the installation
Oct 02, 2009 | HP PhotoSmart 7760 InkJet Printer
Lexmark all-in-one x4690. I am trying to set it
Turn on the wireless on printer , Go to printer option in control panel , Clicked on add printer , Then click on wireless and bluetooth device , Let the wizard detect the printer, once detected put the disk and run software installation Post reply if you need any help, You can contact me for any help +91-9958531192
Chandan
Sep 10, 2009 | Office Equipment & Supplies
How do I connect printer to my notebook?
connect the printer to power, put the usb cable in back of it, but Don't put the other end of usb cable to laptop now.
put the printer On
Now put the Printer Installation CD (which came with the printer) in the computer and install the software & driver.
At the point when it says connect the usb cable to computer, then insert the cable to your laptop's usb slot.
After a while software installation will complete and you can use your Printer.
Let me know if any further clarifications(in that case also let me know the Model of printer)
May 31, 2009 | Acer Aspire 3003WLCi Notebook
I HAVE LOST COMUNICATION WITH MY PRINTER
Unplug printer USB cable, and reinstall drivers using printer disk.
If you have lost the disk, then do the following:
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Nov 14, 2008 | HP DeskJet 880c InkJet Printer
How do i get my printer to print from my pc
depends upon the type of printer u hav,,, if u hav a printer with a USB interconnecting port then u can plug it into ur laptop rightaway by inserting the USB Cable into the laptop's jack. if ur OS is latest then it will automatically detect the printer and its specifications and installation from the CD is not required. else u'll need to install the software for ur printer from the CD provided by the printer company. then give command to print as normal after installation.
Nov 12, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
201 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
