Question about Reliance WATER HTR/STATE 9002564-045 PEX NIPPLES
Low water pressure
A three year old complex with all PEX, i can have low hot or cold [mostly hot] in the same apartment. I have found rocks [pea graval size] at washer hookups. If rocks are my problem thay would problubly be were the line changes size [a reduser and or T]
what would be the best way to pruve this then cure it?
Neal wakeland
Arbor Woods Apartments
    President:
  • 1,489 Answers
That's a tough one. I think blowing out the lines would be the answer to both proving and curing.
I would remove a stop (spigot/faucet) at a low point in the system, connect an air compressor to a high point in the system, slowly apply about 10-15 PSI. Putting a bucket under the line at the low point would catch all the trash coming out and it could be analyzed.
After that it would be a somewhat best-judgement process as to how to blow out the entire system.
Sounds like a sedimet filter on the supply line (post pump) could stop the trash from getting into the system.
Posted on May 13, 2009
Why would I get hot water from only one tap in the house, but still have pressure from all other hot taps, just no heat in the water
hi,
has anyone done any plumbing work to your original plumbing? like a pex upgrade? ive seen rookie installers get the runs backwards and have issues like that. do you have a hot water circulation pump system? one of your zones might have went out, get three estimates from reputable plumbers.
Aug 05, 2017 | Water Water Heaters
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
Rheem powervent 42vp40f does not provide water to all faucets
Feb 2013
1) Copy following links for Intellivent gas control service manual, low hot water pressure, and crossover:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
2) Unknown if tank has hot water > that is first thing to check.
3) Unknown if air intake screen located under burner is clogged with dust that cause combustion chamber to overheat, tripping FV lockout and breaker TRD glass vial.
Requires removal of combustion parts, replacement of TRD, blow out air intake screen, reset intellivent
4) Unknown if there is error code.
5) Rheem does not post service manuals.
However this unit can probably be repaired.
Feb 05, 2013 | Water Heaters
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
I've got the Bosch AE 9.5 tankless water heater.
1) Cheapest and most reliable solution: Install tank-type electric water heater from local box store for $250. Get store coupons, offer 10% off store price. Repairs are made same day with generic off-the-shelf parts.
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
2) Install grundfo water pressure boosting pump.
http://www.ronhazelton.com/projects/how_to_increase_water_pressure_in_your_home
http://waterheatertimer.org/How-to-solder-pipes.html
3) Remove areators and low flow shower heads, Maintain unit as shown in product manual: Delime tankless unit yearly, Clean water filter monthly.
4) Call city and report low pressure and report issue as fire hazard, move to different apartment. Call apartment complex and ask why they didn't read flow requirements for tankless before installing tankless.
5) Call Bosch 866-330-2729 and complain that nobody read the flow requirement or tested local water flow before installing tankless.
Dec 30, 2012 | Water Heaters
After hot water demand, burner stays lit, blew up Pex supply line
Thermocouple has 2 ends. One end attaches to gas control valve, other end sits inside the pilot flame.
Flame heats thermocouple, causing tiny electrical current that is detected inside the gas control valve and keeps the gas valve open so water heater can turn on when thermostat calls for heating.
If pilot goes out, then no electric current reaches gas control, and all gas to burner and pilot is shut off.
If pex line burst, that implies very high pressure, caused by closed system with check valve that stops expansion, or possible clog in the water line, or high local water pressure, or clogged factory-installed heat traps.
Put pressure gauge like BTG100 on the drain valve to check pressure, should not exceed 80psi, install pressure reducing valve on cold water line, install expansion tank on cold water line. Remove heat traps and install ordinary pex-lined di-electric nipples from hardware store.
If the water was super hot, then overheating could have caused the pipe explosion.
However the gas control thermostat is ECO protected, and if ECO (energy cut off) trips because of high heat detected inside the tank or combustion chamber, the gas control will trip off and no longer work, gas control needs to be replaced. Some newer electronic gas controls can be reset, but that type heater uses a thermopile instead of thermocouple.
Thermopile is basically a group of thermocouples, that product more electric current that is used to power electronics inside the gas control valve, which issues an error code on the gas control, and some day will send a text message each time out-of-range event occurs.
Copy following links for troubleshoot resources, including troubleshoot by type of gas control valve:
http://weaterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Jul 12, 2012 | Bosch Aquastar 125B Gas Valve NG - Part...
I replaced a 15 year old Rheem 40 gallon electric water heater with the same - a Rheem heater. After I replaced the old one, I was surprised that there was hardly any sediment build-up at the bottom of the...
These are interior metals, similar like rock used in a sauna, to help keep water hot longer. Here is somethings to check out.
Hello, dave
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Dec 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Reliance WATER HTR/STATE 9002564-045 PEX NIPPLES Logo
212 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
