Question about Xerox DocuColor 12 Printer
I have a problem with my printer DC 12
The image i not comming clear with some then little bit lining in it totaly the copy commng is not good enough so please help me to get with it
    New Friend:
  • 20 Answers
Hi, its seems to be a defective print cartidge especically the scorotron grid. Take out the cartidge, dissasembly the scorotron taking off the screw, dissengage and clean the grid with one wet and soft towell. taking extremely care to not break the wire it is too thin.
Posted on May 14, 2009
What is the cause of line onthe printed image
It's very likely that you have a clogged nozzle on one of the lines. I've owned a number of Epson printers, and they have proved to be great value for the money, but this does happen now and then.
Fixing it - Quoting from their support page (See below for URL) "Please use the printer driver to print out the nozzle check pattern. If there are missing lines in the pattern, it is recommended to run the head cleaning function. If the symptoms still persist after running
the head cleaning twice, it is advised to run the Power Ink Flushing once to see if quality improves. * This function consumes a lot of ink. Before using this function, make sure there is enough ink in the
ink tanks. If there is not enough ink, please refill the ink tanks."
I have had to do this as much as 3 times on some printers, but fortunately the occurrences were few and far between. Note this DOES consume a lot of ink, so stop and check each test before calling another run.
Another possibility if your printer has ALWAYS done this: Change the type quality to "best" quality. It'll slow it down a bit, and use a LITTLE more ink, but not much. Good luck.
Jul 15, 2014 | Epson Stylus Multifunction Inkjet Printer/...
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
Good Luck and Thank You for using Fixya.
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
Line on copy but not on print from computer
The problem you are having is either ink, correction fluid or something has stuck on the scanner pickup image sensor. To clear the material you will need to first open the machine to get to the sensor. To do this pull the control panel forward, it will open just a bit where you load the paper to be sent. If you look down from the top you will see the sensor glass. Use a paper towel sprayed with window clearer. You may have to gently scrub the glass to remove the blockage. You may even be able to see what is blocking the image sensor. After cleaning the glass let it dry for a few minutes before you close it and try copying or faxing.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 3050 All-In-One Printer
How to clear error codes in dc 12
we can clear from NVM read/write
but if know exact solution go for that
www.partsdrop.com/techinfo/enx_DC12info.pdf
this like is use ful for some code
Jan 15, 2010 | Xerox DocuColor 12 Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
Cmyk dots on the print
There are several causes of those.
So go to Xerox.com
Click "support and drives"
then in the product name box, Type DC12
Then any line click support
IN the search box type "spots" and read the relevant solution.
May 05, 2008 | Xerox DocuColor 12 Printer
Vertical white lines in scanned image
Did you try cleaning the little glass strip where the documents go in? Lift the button panel and wipe the glass with rubbing alcohol and cotton swabs or lens paper if you have it. Mine does this sometimes when dust or white out or little bits of paper get stuck on the glass.
Apr 25, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Oct 14, 2007 | HP PSC 1510 All-In-One InkJet Printer
Xerox DocuColor 12 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
