Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemake XL1400 Display
The display is all asteriks and none of the buttons work.  The fuse is OK but don't know what else to check. This happened when an electrician was putting in a new subpanel to our main box downstairs.  None of the other appliances were affected.
  • prodyver Oct 25, 2008
    Hi! I do have the same problem and i tried to do your advice regarding with my GE Spacemaker XL1400. The display is all asteriks and none of the buttons work. The fuse is OK but don't know what else more needs to be checked. thanks.
This may seem strange but my microwave ended up doing the same thing..the solution courtesy of another website pointed toward RF interference from that faulty magnetron ge is famous for...what cure it was piece of the static paper used to protect computer parts..check it out by opening the side panel and leaning it away from the magnetron.mind started up immediately no problem ..got a piect of the static paper,fashioned it to fit...and problem solved
Posted on Oct 19, 2007
Just did what fixit60 recomended and it worked.
Posted on Oct 28, 2008
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
My ge spacemake 1800 microwave just stop heating things this morning do i need a part ?
this happens alot with ge spacemakers. if you replace the magnetron it should function properly. if not go to sears and buy a better brand one
Dec 05, 2010 | GE Microwave Ovens
Power went out. Microwave just scrolls press clock!!!!!!!!!
Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
Hi, This is Mike. My GE spacesaver xl1400 is shutting off as if it has lost AC power seconds after hitting the start button. The last couple of times it reset itself and now its dead. (power source is ok)....
-thermal cutout
-fan/fan motor
-transformer
-capacitor/diode
-circuit board, triac or magnetron
any of these could be the culprit
any of these can be tested
let me know if you need further instructions
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Seems like microwave is locked on clock
You have to set a time (any time) to use.
Press CLOCK, press number 2 then 2 then 2 again and then press CLOCK again. Does it say 2:22?
Everything should now work.
Do not run Empty, do not use any metal in there and do not use alot (MW kills all the vitamins and nutrition in food - like eating MUD for your body) .... and don't forget to reset the CLOCK ;-)
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
110 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
