Question about Fujitsu Siemens LifeBook E4010 Notebook
Xp wont boot up, gives option of safe mode, safe mode with config, restore last work etc but none of these work? Any ideas
Hi guys, my e4010 wont boot up, it has xp but it is asking for me to choose safe mode, safe mode with config, restore using last work etc but i have tried all these options and to no avail
  • 24 more comments
  • stathama May 13, 2009
    it wont allow me to go into safe mode at all, i dont have the xp disc either as it was installed when i bought it. i have xp on a pc tho, maybe i could copy it and transfer it to the laptop?
    Hi Sirwriter, I have downloaded xpquick.exe to a cd but still cant get the laptop to do anything. I have put the cd in the drive and turned on the laptop, holding down F3. It made a constant bleebing sound then the screen says ERROR 0210 Stuck Key with an option of F1 to resume, F2 to Setup?
    Hi ozhandyman, tried both F5 and F10 but it came up with ERROR 0210: Stuck Key
    Sirwriter, I have got into PhoenixBIOS Setup Utility but its asking for a password which I have no idea about?? What now???
    Hi Sirwriter, did the cold boot, nothing, did the tapping thing and it went straight to PhoenixBIOS Setup Utility but is asking for a password which I dont have?
    Hit enter, comes up Setup Warning. Invalid Password [Continue] ?
    just goes back to enter password
    hey we have a different screen which i havent touched yet till i tell you what it says:
    Windows Advanced Options Menu
    Please select an option:
    Safe
    sorry let me continue
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Command Prompt
    Enable Boot Logging
    Enable VGA Mode
    Last Known Good Configuration
    Directory Services Restore Mode
    Debugging Mode
    Disable automatic restart on system failure
    Start Windows Normally
    Reboot
    Return to OS Choices Menu
    phew lol
    did you read the rest of my reply?
    ok, it now says
    Please select the operating system to start:
    Microsoft Windows XP Professional (which is highlighted)
    shall I hit enter to choose?
    it also says at the bottom,
    For troubleshooting and advanced startup options for Windows, press F8
    NOOOOOO
    Its done it again, ahhhhh lol
    hiya, Im at the bit where it says
    Windows Advanced Options Menu:
    Safe Mode
    Enable Boot Logging
    Enable VGA Mode
    Last Know Good Config
    Debugging Mode
    Reboot
    it doesnt have any option other than Microsoft Windows XP Professional but it says at the bottom
    ok gone back to the windows advanced options menu shall i try safe mode now?
    sorry but its gone back to the original screen again....its going in the dustbin if it continues ARGHHHHHH
    it came up with a blue screen saying the system is booting in safe mode, then it went back to its original loop
    hey you still there? Im back at the Windows Advanced Options Menu again, any other suggestions?
    thanks alot, i will wait a little while if you think you can help me, just looked at the website but the discs are $49 and to be honest i could take it to a repair shop for less, anyway its not so much fun is it?? Sincere thanks for all you help thusfar, and I look forward to hearing from you soon, I will let you know if i manage to sort it in the meantime.....I can feel a very large glass of wine coming on! Thanks again, speak soon, Amanda :o)
    ok, one more go...bare with me
    no, just went back on its loop again, it must be getting extremely dizzy by now...lol...hysteria is setting in!!!
    Thanks Dan, look forward to hearing from you, I really appreciate your help. Amanda :o)
  • stathama May 19, 2009
    Hi Ozhandyman
    The disc would be most helpful as i am still no further forward.
    Amanda
    Hey Dan, tried without touching anything with the cd in and that didnt work either. Any more suggestions? Amanda :o(
    hi Dan, tried tapping f2 then went into safe mode with command prompt....got black screen with loads of writing then the blue screen and back to the dizzy loop again, Ive ordered a disc off ebay today, item number
    280344944844
    dont know whether that will help the situation? Thanks for your continued support, Amanda :o)
  • 323 Answers
Will it allow you to enter the safe mode? If so, and you can choose help and then restore you can back up to a date before this problem began. It sounds as if the MBR (master boot record) is contaminated.
If you made a set of restore discs when you got the computer, now is the time to use them. If you are lucky enough to have an original Windows disc, you can place that in the CD/DVD and go to the point where it asks if you want a complete install or repair an earlier on. Repair should do it, although it may still ask if you want to repair the MBR.
There are other options too, one of which is using the D: partition on your hard drive which contains restore, to restore your computer to the same state in which you bought it. However, this will lose all your data, and you will only have the programs like when it was brand new. Let me know if none of these work.
Sirwriter
Posted on May 13, 2009
  • 26 more comments
  • Dan Todd May 13, 2009
    Hi Stahama,
    Copying the XP system off another computer to a disc and using that will not work.
    However, if you have XP on another computer, you can make a boot up disc as follows:
    Put a formatted CD in your drive.
    Go to http://www.bootdisk.com/bootdisk.htm
    Download xpquick.exe onto the CD. Close it out and transfer it to your laptop. You may have to enter set up to change Boot from CD as your first choice. Usually you can hold down F3 when you turn the computer on to enter set up.
    This CD should give you a bare minimum set up as in safe. Choose system restore and pick a bold date before you had these problems.
    If this does not work, write me back.
    Sirwriter
    Hi again,
    Try turning it off, then booting with the CD in. If that doesn't work, hold F2 down while booting and enter set up. Go to
    Boot up priority and select CD or DVD as the first. Then exit and save changes. It should begin to boot with the CD, but if it doesn't try another cold boot. If you cant boot, or get into setu, let me know.
    Sirwriter
    By the way, if holding down the key results in the stuck key notice, try repeatedly tapping the key with your finger.
    Sirwriter
    A password, hmmmm? Try just hitting enter. Do you have a password you normally use to boot up with? If so, use that. Most of the time hitting enter will do it.
    Sirwriter
    If it will allow you, continue. I'm waiting for your reply.
    Sirwriter
    Okay, now that we know tapping works, shut down, restart, and tap the F8 key until it enters safe mode. Then choose system restore, and pick a date a day or so before this started.
    Sirwriter
    Go to safe......
    lol, choose last known good configuration.
    Yep, I said go with last known good configuration...did you get that?
    Yes, hit enter
    Arggggh.....choose advanced if you haven't alread hit enter.....lol
    Ok....didn't get my reply to you quickly enough.....turn off....reboot, tapping F8, and let me go back and read what happened, BRB
    After it says choose operating system, choose safe mode
    Did you give up???
    Sirwriter
    Okay, hit "last kown good config". When it asks you which operating system with Windows highlighted, choose safe mode....
    Did you get my last comment about safe mode?
    Press F8.....
    Yep, yep, yep.......
    Stahama,
    Try one more time, and get to where it says Directory Services Restore Mode. K?
    Sirwriter
    Well, this is a tough problem. Right now, you have two choices and the first will wipe out all your date and give you a fresh operating system. You'll have to reload any programs you have.
    !) Buying a new operating system disk. Of course that is the most expensive route.
    2) The other is going to Spotmau.com and downloading their repair disk. I own it. I have used it to boot machines with damaged MBR's, you name it.
    I'm sorry this is the best I have to offer you at the moment, but if you can wait a day or two I will network with my cohorts and see if we can ccome up with another choice.
    Sirwriter
    Hey, maybe safemode with command....
    Amanda,
    It was fun!. If you can wait a short while, I'm certain I can come up with something. I'll just reply to this thread, ok? Don't lose heart,
    Dan
    lol. ok, baring.....
    Sorry, Amanda....
    I really want to see you get it up and running...remeber when I suggested putting that program on the CD and trying? You said you tried while holding your finger down. If you didn't try with the CD in without touching, you might try that. Otherwise, look for me tomorrow am, ok? Take very good care Amanda, and thanks for your patience!
    Dan
  • Dan Todd May 19, 2009
    Hey there Amanda!
    Ok, let's see. Correct me if I'm wrong, but here are the following we've tried so far, correct?
    Safe Mode
    Have I missed anything?
    Dan
    If I haven't, try booting again and tapping F2 this time to get into set up....
    Comment
    Amanda,
    What we want to try is safemode with command prompt...
    Dan
    Amanda,
    That looks like a real find if it does only half of what it says it will. Please keep me updated!
    Dan
    Problem Solver:
  • 5 Answers
This problem is windows xp
some file is missing'
repair ur windows xp
recover ur windows xp
    Problem Solver:
  • 13 Answers
Hi before safe mode keep F8 down then go across to restore hit the y then F5 or F10 it should boot up
  • 1 more comment
  • ozhandyman May 13, 2009
    well i got the same as you xp and i have found i reboot dics on ebay for £2.99 +£1.00 so for £3.99 it worth it lol
    restore last know working
    amanda i have a reboot dics ere lol
    if you dont get any joy then i could pass it on to you lol
  • 114 Answers
You may have to repair your Windows installation. If you have the Windows disc, then follow the instructions as given in this link
http://www.windowsxpprofessional.windowsreinstall.com/sp2sp3installxpcdrepair/indexfullpage.htm
MY ASUS F80Q WONT start up, it stuck in the Microsoft corporation
Hi. First option: For that symptoms try restart PC then before booting press F8 to see.(for windows xp professional and home edition. operating system )
safe mode safe mode with networking safe mode with command prompt enable booth logging enable VGA mode last known good configuration (your recent settings that worked) select this option by highlight then press enter key. if same problem? restart PC again then select safe mode wait for booting. already use that option not yet happened same problem. jimmyverdade_46.jpg
Second option:You need to reinstall fresh installation of operating system like windows xp,windows vista,windows 7 version etc.
Hope can help you.
Jun 17, 2011 | ASUS F80Q-X2AM Notebook
Brought a advent 7113 2nd hand and it was working great but i was updating the windows programs/ however the computer stut down during and now its struck on a loop on the startup. giving options safe...
First try to boot with last know good setting if this doesn't work boot into safe mode and choose a system restore point and then retry you update again. Always be sure your laptop is plugged in when installing or doing updates, since if the battery dies in the middle of an installation or update your stuck like this.
May 19, 2011 | Computers & Internet
STOP: 0x0000000024 that is the error message I am receiving and can't seem to get past the screen that gives you the option to start in safe mode
if this happens when starting to boot to Windows, try last known-good config. When system is restarting, tap F8 a couple of times to get to the Advanced Options menu where Safe Mode is also listed. Select Last Known-Good Configuration if available and press Enter. If this does not work, try selecting Safe Mode. If you can get to Safe Mode, you can try System Restore to a previous restore point available when your system is working properly. If none of the things work, try Windows repair or reinstall. Make sure to try to backup data if you can before doing any reinstall or repair.
Sep 16, 2010 | Compaq Presario Notebook
On my emachines d520 running windows xp the system hangs up at boot and gives this error message.
hit the R key many times when booting up and will bring you to the recovery tool and try the options it allows you to like (last known good config.), (safe mode) do a virus scan then when you get in, and or a restore from there ok try these and if nothing works then shoot me the error code it's giving you and I go from there ok good luck and have a nice day the fixist
Jun 26, 2010 | Computers & Internet
Unable to load desktop ASUS 1005HA XP SP3
Hi
It seems you are stuck in a windows loading loop
Please do the following
1) Go into safe mode (swith the pc on and keep pressing F8 repeatedly until you have a menu presented to you, from the menu choose safe mode)
2) Once loaded click on Start>Programs>Accessories> System Tools> System restore
And restore your computer back to a point before the update was done
if it still loops when using safe mode through the method shown above then unfortunaltey you will have to reformat the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How do you access the boot list on my compaq armada 1750
Tap the F8 Key as soon as the Laptop is powered on, keep tapping it till it brings you to Boot Choice Menu Options.. Options such as: Safe Mode, Safe Mode w/ Networking, Last Known Good Config..etc... are listed here..
Press and hold the F12 Key If You Need To Get To Boot Choices.. Such As Boot From CDrom, Boot From LAN, Boot From USB Device..
Nov 17, 2009 | Compaq Armada 1750 Notebook
Cant boot,get window saying restore last good known config etc
If you are asking how to re-install Windows XP, you must boot from the cd to do that. Either change your bios settings to boot from the cd first or immediately after the POST screen press F12, then choose boot from cd and when directed, press any key to boot from the cd.
If you're asking why your pc isn't booting there are many reasons it might not boot - virus, driver problems, hardware failure. Need more information if that's your question.
Jan 18, 2009 | Intel D915GAV Motherboard
Zd8000 wont boot up
try to get into SAFE mode... tap F8 repeatedly when you first power on. You should get a safe mode boot menu, select last known good profile and press enter.
If this does not work reboot go into SAFE mode and select Safe Mode from menu and see if it will boot up.
You may get a pop up to use system restore, say yes, select restore to an earlier date (or similar) then use the calander to select a restore date that is PRIOR to the problem starting.
If this does not work boot to safe mode again and say NO (cancel) to use system restore and see if you can get to the desktop
post back results for further troubleshooting
Jul 16, 2008 | HP Pavilion zd8000 Notebook
Fujitsu Siemens LifeBook E4010 Notebook Logo
1,218 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
