Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer only working on high/low spin
Other cycles not working at all
  • 47 Answers
I DON'T KNOW, BUT I WOULD CALL YOUR REPAIRMAN RIGHT AWAY AND SEE IF HE CAN CHECK YOUR PROBLEM. I AM NOT AN EXPERT, BUT I DO KNOW WHEN SOMETHING NEEDS TO BE FIXED, I LEAVE IT TO A EXPERT.
RODNEY
Posted on May 14, 2009
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The clothes are still very wet when the cycle is done, and there is a little water sitting in the bottom of the machine. Is something wrong with the spin cycle?
does the drum turn on high spin if it does is there a low and high for the spin also check the filter which should be located at the fort bottom of the machine it might be blocked
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
No high spin
Make sure you are set for normal cycle. Some permanent press cycles only spin on low. Also check that your drain hose is not kinked. If it is the water may not be draining fast enough.
Will not high spin
The brake assembly is failing ,try this if you can,loosen the 3 transmission bolts about a quarter inch and try it in spin.If it picks up speed than you are going to be due to have the break assembly replaced.High cost repair. :(
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
