Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
Parrot keeps redialing the last number....non stop!
When I am in my car...out of nowhere, my parrot dials the last number that I called from my cellphone and if I press the hang up button on the parrot, it does not disconnect the call, I have to hang up from my cell phone. Once I do that it recalls the number again...it will keep on doing it until I shut my phone off...what is happening and how do I resolve it?
SOURCE: Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Posted on Feb 18, 2009
SOURCE: passcode for hands free parrot bluetooth device
on the device
go to settings - pair with phone... - other phone
and the pin code will be dispayed on the screen
Posted on Apr 08, 2009
  • 95 Answers
SOURCE: Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Posted on Mar 18, 2010
  • 95 Answers
SOURCE: when turning on my car my parrot starts calling on its own
Some of the auto synch in relation with software troubles or simply the numbers of contacts can be the trouble.
I do not remember that blackberry used an auto synch at the begining, then for me it seem to be complicated to resolv, cause not specialy and easier trouble to resolv.
The type of synchro via bluetooth may be the trouble between both devices.
You can simply pair the phone via the specific menu without synch and send the contact one by one via object push with Bluetooth.
SOURCE: pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Posted on Mar 27, 2010
How do u install it in your car
there is a users guide and maunals in the package,just follow instructions:
Please note this car-kit will not work in cars that use optical cabling. Check with your car dealer before ordering. Also, since this car-kit is installed by hard-wiring to the existing car stereo, professional installation is highly recommended.
Turn on the car engine and the phone connects wirelessly to the Parrot CK3100 Car Kit. The screen unit has easy-to-navigate menu options just like your phone, and your mobile phone book is wirelessly downloaded to the car kit. Calls can be dialed either through the screen, or by using voice-recognition speed dialing. According to your phone's model and firmware, most features are accessible from the hands free console, including one-touch redial, dual call, and auto-answer.
Feb 23, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Parrot keeps "calling" and counting time when I turn on car....bluetooth is connected to phone but I did not dial anyone!
You will need to update the software in this parrot, you can do this by downloading the parrot update manager from parrot web site, you will need a Laptop with Bluetooth to send the file to the parrot. If you cant do it the have a look at parrot.com and look for your nearest parrot engineer.
Jun 15, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
When will the software update be available for "keyword" problems I'm having with my Samsung Rugby phone? When hands free dialing, with my Parrot, the unit onty dials the default number or the first number...
ask parrot is the best answer i can can give, go to parrot.com and follow contact us to send an enquiry. I do speak to parrot regularly and i know that some samsung phones are them lots of problems.
Dan.
Mar 02, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot CK3100 won't import Contact list from Nokia 6210 Navigator
Try this.
* To send several contacts at once:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / MARK-UNMARK / MARK
* Select your contacts to send then select OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for available devices
* Select the CK3100 from the list and the contacts are sent to your car kit
Nov 13, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Problem updating Parrot LS-GPS
The Parrot manual states that the software update can be conducted via bluetooth (BT). I've managed to get BT connectivity both the laptop recognising the Parrot as a headset, and indeed it cts a PC speaker in the mode, and also from the Parrot linking to the laptop. But wehn using the Parrot Software update tool, and attempting to connect via BT, non of the displayed COM channels work. Authentication fails. The laptopn connection also only stays up for about a minute. Confusingly the Parrot also offers an update item in one of its menues, and supplies a 4 digit passowrd, but I can't see how this can be used. Any ideas?
Sep 14, 2009 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
Parrot v508c
Turn off key word voice prompts/voice commands. The Parrot is listening for key words like "phone" or "call" or "hang-up". When it thinks that it hears this it will beep, or call someone.
Sep 06, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
191 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
ray gallant
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
