Question about Hansgrohe Mistral Handshower, Polished Brass
Can the hansgroeh mistral showerhead be dismantled for descaling?
WE live in a hardwater area - all shower heads get extremely clogged even with frequent cleaning with vinegar/ chemicals etc. My husband decided to open the hansgrohe shower head for clearing lime debris - but now i can't seem to be able to put it back together !! Is it possible to fix it??
2 Suggested Answers
  • 62 Answers
SOURCE: I have lime deposits and hard water spots on my
use a product called CLR (calcium lime rust0 do not scrub.
Posted on Jul 16, 2009
How do I take apart a moen shower head?
You can remove the head from the shower arm by taking a crescent wrench. Put it on the flat sides of the nut on the showerhead and unscrew it counterclockwise. There is no way to take apart the Moen showerhead. If the reason you want to disassemble the showerhead is to clean it because it is clogged, disassembly is not needed. Just fill a Ziploc bag with a 50-50 solution of vinegar and warm water. Place the bag onto your shower head so it is fully immersed in the solution. Use a rubber band to hold it in place. Let it soak overnight and then take a toothbrush to any of the white scaly matter that might remain.
Aug 10, 2015 | Moen Home
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
CLOGGED SHOWER HEAD - HOW TO CLEAN
You can dip a shower head and CLR or Oxsee clean. You can do it the old-fashioned way and use a needle or a small nail and clean out every little hole or you can run high-pressure water through the opposite end of the showerhead. Little carbon and gasket material finds its way through your screens and filters into your house and comes through your showerhead clogging it. if you can get those clogs out by simply running water backwards through it, you might solve your problem, but you must take it off to do this. simply's unscrew it counterclockwise. it should come off remember to use thread tape to put it back on and make sure the rubber gasket is also inside
Jan 31, 2015 | Dmm Symmons Temptrol II pressure balancing...
Why does the water from my shower head not come out straight
Is it an old showerhead? How long have you had that particular showerhead installed? What state do you live in?
Jan 26, 2015 | Home
We installed low flow shower heads on a symmons temptrol system and now the showers do not get hot and the temperature flustuates.
You might want to change out to a different model. The highsierra showerhead company makes a 1.5 gpm showerhead that works well and won't clog. It fits a standard male thread stem so maybe you would need an adaptor.
Jan 28, 2011 | Dmm Symmons Temptrol pressure balancing...
The shower head has a leak around the ball area
Take the showerhead off above the ball. You may need to hold the pipe with one wrench and turn the showerhead with the other. Put teflon tape on the threads that are exposed on the pipe and then put the showerhead back on as tight as you can get it.
Sep 07, 2010 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
I don't have enough water pressure to make cofee. Very little water comes out of the shower head. The shower head is clean, it is not plugged. I suspect it is the pump? Please advise
I had the same problem: clean showerhead, machine pumps hot water just fine, but very little brewhead flow. Descale made it worse but that was a big clue! I took apart the brewhead and found grains of scale in the boiler, like pulverized beach shell:
Some of those bits apparently made their way into the three way valve and clogged it. I could not blow air through the channel between the plunger and the boiler. Not surprising: the inlet hole inside the valve is TINY and clogs easily.a0bc8304-2405-4fdb-a444-21cf80e7701a.jpg
Once I got this part cleared up inside (and cleaned out the rest of the scale from my boiler so it didn't immediately re-clog!), my brew flow was restored.
Sep 05, 2009 | Gaggia Classic Espresso Machine
Shower body three way diverter problem, no water to one port
try taking the shower head off and see if there is something stuck in it. sometimes things will come through the water lines and lodge themselves in the valves as well. if the shower head isn't clogged try dismantling the valve that turns the shower head on and then turn the water on when its out and flush the port out.
Jun 11, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
The shower head is clogged how do I clean it?
get some CLR which is calcium lime and rust remover.Unscrew it from the pipe on the wall with the water off and pour it where the water flows into the head and wait for it to drip out the jets.
Apr 21, 2009 | Grohe 28 783 000 Rainshower Jumbo...
Grohe Atrio Bath Shower Mixer Flow Problem
Check for a flow restrictor in the showerhead, also a clogged intake screen or filter in the showerhead. or hose or pipe...
Nov 25, 2008 | Plumbing
Hansgrohe Mistral Handshower, Polished Brass  Logo
116 people viewed this question
Top Hansgrohe Home Experts
Daryl Gleaton
Dan Apthorp
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
