Question about Compaq Presario 5000 PC Desktop
Automatic one hour shut down
My computer is automatically shuting down after one hour.what shouid i do for remove this?
  • sahilbpl06sa May 11, 2010
    click star menu > setting > control panel > power option & power schemes is first option & change the setting turn off monitor set never
    2 turn off harddisk set never& 3. is system stand by set never
    apply setting
    and restart ur system
    the cheak
  • Compaq Master
  • 4,806 Answers
Hi there.
Click on the start menu and go to the control panel, select power options and there you can set the PC to never shut down.
Good luck and thanks for using FixYa!!
Posted on May 13, 2009
Jeep wrangler 2.5 standerd turns over has fuel but no spark checked all relays and crank sensor computer is shuting down asd relay as soon as key is on. what does pcm look for when asd relay is not...
Is it an automatic transmission?
Have you try to start the Wrangler in Neutral.
On automatic transmission there is a neural safety switch.
When it's not send the correct gate position signal (P R N D... ) to the ECU not energize import relay like ASD.
Check for loose linkage to the transmission. + lube linkage with white Lithium grease spray.
Check for loose wiring to the neutral safety switch.
Aug 11, 2011 | 1997 Jeep Wrangler
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
Feb 23, 2010 | Acer Aspire 5610-4648 Notebook
My Acer Aspire 5000,keeps shuting itself down during startup
this is an indication that your computer has so many dust build up inside, CPU or the processor generates heat, even when in start up mode, when the heat doesn't dissipates somehow, there is a protection that will shut off electrical circuits to prevent further damaged to your whole computer.
that is why it is shutting by itself automatically. chances are there is a lot of obstruction in the cooling system, particularly the heat sink.
you need to send this to a technician, im afraid
hope this helps
Jan 08, 2010 | Acer Aspire 5000 Notebook
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Computer keeps shuting off automaticly
your computer is virus infeted.
when upower up the computer prerssF8 key then enter in safe mode.
then type "msconfig" in run then go to stratup it is last tab
then disable all stratup then restart your computer.
also if u have updated antivirus like avast scan your computer in safe mode.
Mar 26, 2009 | E-Machines eMachines Desktop PC
When i turn my computer it automatically shutsdown
your infected with a virus. the easiest way to remove the virus is to scan your hardrive in another computer with updated antivirus.
Jan 28, 2009 | Computers & Internet
Override Dell Latitude D600 laptop automatically shutting down
yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
Turn of the display> change to four hours
Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
I hope this helps
Jan 10, 2009 | Dell Latitude D600 Notebook
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Auto shut down
neeed some answer please regarding above matters
Oct 18, 2007 | ASUS P525 Smartphone
Compaq Presario 5000 PC Desktop Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
