Question about Sony Playstation 3 (PS3) Console
I bought this HD cable so i could play in HI DEF but i wanted to play it on my regular t.v and it wont work.
  • leadkilla25 May 13, 2009
    I tried using my original component cable, after I played it with an HDMI cable, and it did not work. I no longer have my HDMI cable. What should I do?
  • 56 Answers
Leadkilla25 after everything is connected and you go to turn on the ps3 hold down the button on the console you will hear the initial beep followed by another about 3 seconds later this will reset the setting back to regular connection
Posted on May 13, 2009
    Sergeant:
  • 273 Answers
Hd doesn't work on normal tv
  • 46 Answers
Hi def will only work on a hi def television. its the tv part which is the problem as the xbox 360 is already hi def.
I have downloaded a handful of games from the Nintendo Wii Shop. When I go to play one of these games, the screen continues to skip and doesn't work. I have absolutely no issues through when I insert a...
HI on my wii I noticed the same problems when using high def a/v cables and I had to hook the regular a/v cables up. Are you using regular standard a/v cables?
Nov 24, 2010 | Nintendo Wii Console
When i turn my xbox 360 on it will play the sounds but no video
If your using the hi-def cable(red blue green) check that its switched to either standard of hi-def. Also if your using the hi-def cable it wont work if u have the white head in the same time as red blue green! Hope it works for you!
Mar 14, 2010 | Microsoft Xbox 360 Console
Have xbox 360....got used,no instruct. book,was hooked to flat screen tv, no longer have flat screen tv, have regular tv hook up game comsole to tv, wont work.....why
If it was hooked to a flat screen it was most likely on high def. There is a switch on the connection to the tv to make it work on a regular defination tv. Just slide the switch over to regular and it should work. Hope this helps.
Sep 12, 2009 | Microsoft Xbox 360 Console
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Hi-Def?
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Mar 03, 2009 | Hitachi 53FDX01B 53" Rear Projection...
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
What does HDMI mean?
Only If you Play high def or blue ray disks on the player///regular disks will look even better then before but not quite as good as a high def or blue-ray disk!
I hope this fixes ya up!
(please use the rateings so we can keep this site FREE!)
Dec 14, 2008 | Hitachi 57F500 57" Rear Projection...
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Grainy picture
hi, if the tv is not high def then the picture will not be at its best especially if it is getting converted to a analogue signal. hdmi will be much better.
Dec 11, 2007 | Panasonic HDC-SD5 Flash Media Camcorder
Hi-def dvd
This is not a High Definition DVD player, it does upscale a regular DVD to HD resolution, but that's just an electronic trick.
Also, Toshiba has abandoned the HD-DVD standard (did you find the discs on sale?), you'd need to find a BluRay player (like the Playstation 3) to play high definition DVD's.
Dec 05, 2007 | Samsung HT-Q100 System
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
