Question about HP Officejet 7210 All-In-One InkJet Printer
Black and color cartridges
I have one black and one color cartridge in my printer but it keeps giving me an error message:
"Insert Black or photo printer cartridge in right stall"
It won't stop!  Help me....
  • 4 more comments
  • roteyk Nov 09, 2007
    yes
  • kathyd913 Nov 27, 2007
    I get the same message. I spent a morning with HP online tech support, and after all their diagnostics and suggestions to fix it, they tried to sell me the new model of printer for $399. The little metal clip (looks like a opened up paper clip) inside the right cartridge compartment will not stay seated properly. I put in back in place and secured it with a bit of superglue, but apparently that wasn't the problem, since it still won't recognize the black cartridge. Is it time to give up, or any other suggestions?
  • Anonymous Mar 19, 2008
    New Black Cartridge is not being recognized by printer.
  • Anonymous Apr 08, 2008
    I'm getting the message "check black cartridge, etc" and the printer will not copy, fax etc. I tried:
    1. Shutting down and re-starting
    2. New Cartridge
    3. Cleaning it with canned air
    4. Cleaning the stall and the cartridge with warm water
    Nothing worked!
  • johnnpam Apr 14, 2008
    Did everything that kathyd913 did, plus now cartridge, cleaned contacts on cartridge and printer, rebooted printer, etc. Any other suggestions?
Have one black and one color cartridge in my printer but it keeps giving me an error message:
Posted on Nov 09, 2007
SOURCE:
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Jun 15, 2011 | Dell 948 All-In-One InkJet Printer
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2011 | HP Office Equipment & Supplies
I am getting the following error message: Black/photo cartridge missing
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
What is error #2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: contact Dell.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, contact Dell.
No: Install the color cartridge. If the printer fails, contact Dell. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Mar 23, 2010 | Dell 962 Photo All-In-One InkJet Printer
Dell 944 all in one - used NON-Dell Print Cartriges - Cheaper
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Sep 13, 2009 | Dell A940 All-In-One InkJet Printer
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
Yes: Continue to Contacting Lexmark.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Sep 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    OR
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP 1315 all in one printer/ Ink cartridge problem
    clean the printer contacts with a Q tip and video head cleaning solution , re install the cartridge try again , hope this helps
    May 05, 2008 | HP PSC 1315 All-In-One InkJet Printer
    HP Officejet 7210 All-In-One InkJet Printer Logo
    187 people viewed this question
    Clive
    Clive
    Thomas F. Schneider
