Question about Whirlpool LER4634J Electric Dryer
Whirlpool LGR4634JQ1 Ignites the first time, then will not ignite
The dryer starts to get hot then will be cool in a few minutes. I look through the peep hole on the front of the dryer while it is running, and and see orange from the element, and this ignites the gas (we have propane). The flames go for a while, then go out after a few minutes. After some tumbling, I can hear the click when the gas starts to feed, again the element glows orange, but the flames will not ignite. Help! Thank you.
  • cmnelson29 May 14, 2009
    I could use a little run-down on how to change them, if you don't mind. Its a Whirlpool gas, converted to run on propane. The model is LGR4634JQ1, the serial is ML3124274, type B433-NAT-1206006-FM22. A part number would be very helpful, too. Thank you so much!
  • slicks70 May 19, 2009
    The dryer starts to get hot then will be cool in a few minutes. I look through the peep hole on the front of the dryer while it is running, and see orange from the element, and this ignites the gas. The flames go for a while, and then go out after a few minutes. After some tumbling, I can hear the click when the gas starts to feed, again the element glows orange, but the flames will not ignite. It’s a Whirlpool gas. The model is LGR6620PQ1, the serial is MT1105463, type DWJR-NAT-1206006-FM-22. A part number would be very helpful. Thank you so much!
    President:
  • 1,136 Answers
Hi, You will need to change the coils on the top of the gas valve. They are a plug in coil. This is a very common problem. If you need assistance on how to change them or the part#, I can help you. I would need you model#.
Thanks
Vic
Posted on May 14, 2009
  • Victor
    Victor May 14, 2009
    Being able to change your own Whirlpool dryer belt is a practical way of saving money. This article provides you with steps on how to change a Whirlpool dryer belt.
    window.google_render_ad();
    Make sure that you have unplugged the appliance. This is to ensure safety while you are fixing your dryer.
    After you have Disconnected the power, remove the lint filter to expose the screws. Take out the two phillips head screws. Then using the standard screw driver, put it in between the opening of the top and front of the dryer and pop it up. Note: There is a spring clip on both right and left edge in the front) . Flip the top of the dryer up and rest it against the wall if possible.
    Look for the two 5/16" or 1/4" screws that are located on the inner side of the front upper corners of the dryer. When you have found these screws, hold the front of the dryer then remove the screws. Once the front panel is loose, slightly lift upwasrs on the panel and set it off to the side. Note: You should not have to remove the wire leading to the door switch. This is done by pulling out the top and lifting it off the tabs at the base.
    Now locate the gas coil below the drum. You will need to remove the two phillips head screw on each side of the metal bracket holding the two coils to the gas valve. Notice which coil goes where. Make sure that the sleeve on the three wire coil gets put back on the post before you put the new coil on. Sometimes the sleeve will stay inside the ols coil when you remove it!! Put the metal bracket back on the coils making sure the little knobs on the coil fall into the holes in the bracket.
    Now you are ready to put the front panel back on and the top.
    This is also a chance for you to clean your dryer. Just vacuum out the lint. DO NOT stick the wand of the vacuum inside the burner housing.!!
    THe part # is 279834. If you have to buy it online, I would appreciate you giving my parts site a chance. www.whirlpoolpartssurplus.com
    Let me know if this helps.
    Vic
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Gas dryer ignites but wont stay lite
Try shorting out the Hi-limit sensor(Lg calls it that, don't know for whirlpool). See if that does anything. If it fixes that, don't leave it like that. replace it and the other fuse by it as well.
Nov 30, 2009 | Whirlpool Dryers
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryer not staying hot
gary suspect the coils on the valve are bad the coils come in a kit so change both
May 18, 2008 | Dryers
Check for a restricted vent. Clean vent and check for kinks. Make sure lint screen is clean. If you do-not have good airflow due to a restriction, the burner will not stay on. It's a safety thing.
Nov 18, 2007 | Whirlpool LER5636P Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
653 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
