Question about Mtd Garden
No start starts with starting fuild then dies there is gas flow to carb mower ran last week about 1.5 hrs put it away no problem took it out today no start
  • 246 Answers
Hello djb4297:
Not knowing the Make or Model of the Engine; I am Sending a Basic File for Checking the Carburetor.
>>The Following is a Basic Instruction File I made for Checking the Carburetor Solenoid. Any Input is Appreciated.
>>**Check for Current/Voltage (10.5 VDC Minimum) to the Carburetor Shut Off Solenoid. If the Carburetor Shut Off Solenoid has Current, then On Some Solenoids you can Remove the Needle and Replace the Solenoid to Test them.
>>****PLEASE DO NOT OPERATE THE MOWER WITH THE SOLENOID BYPASSED IN THIS MANNER. THIS IS "ONLY" FOR TESTING.****
>>For Others, Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 1/2" to 3/4" Long for the Horizontal Mount Solenoids and 1/4" to 1/2" Long for the Vertical Mount Solenoids. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid.
>>***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES***
>>Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jet Properly.** **Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. There is Some Slop/Free Play in the Solenoid Pin. Usually the Electromagnet is Simply Not Pulling the Pin as it Should or there is a Small Bur on the Pin. Use 440 Wet Dry Sand Paper and Engine Oil to Clean the Pin. Wet the Sand Paper with Oil Until it is Flexible and then Lightly Polish the Pin. Clean and Lightly Oil the Pin before Inserting it Back into the Solenoid. Just a Film of Oil is All it Takes.**
If No Carburetor Solenoid, then the Carbureotor Float Needle Valve is Sticking and I Suggest you Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
2002 Cavalier starts then dies. Started about 1 week ago. Let sit overwrite started fine next afternoon. Ran great for several hrs. Started dying again. Replaced fuel filter, Ran great for a day. Now it...
Had a 89 cavalier did that start then die it map sensor. Also check ground wires if the become too corroded they won't start sometimes just run weird
Jan 21, 2015 | 2002 Chevrolet Cavalier
John deere L118 engine just stopped while mowing like it ran out of gas or electrical shutoff, started back once and ran for a few seconds and died again. it just had a tuneup last month, I also put o
WATER IN GAS CLOGGED CARB REBUILD IT IF WATER IN GAS DRAIN IT OUT DRIAN CARB BOWL MAKE SURE NO WATER IN IT TRY TO START IT IF DOES SAME CHECK COIL SEE IF IT IS SPARKING WHEN IT SHUTS DOWN IF NOT REPLACE COIL 60.00 THEN CHECK FUEL PUMP GOOD PRESSURE 3TO 5 LBS CHECK ALL THIS AND LET ME NO WHAT HAPPEN WILL GO FROM THERE TO CHECK MORE THE REDNECK
Sep 01, 2014 | Garden
Carb full of gas
sounds like the float is sticking inside the carberator might need new needle and seat as wel as a float check to see if float is gas logged
Jul 06, 2012 | Parks Optical 13.5hp Briggs And Stratton...
I ran my mower out of gas and I know I had some water in the tank. I filled it wirh gas and 350 ml of isopropyl yesterday and it still won't start today. It fired up twice yesterday but stopped right...
Your condition sounds like a particle may be plugging the carb. IF you have good fuel flow to the carb, then take the carb apart and blow out any passageways. While there, drain all fuel and put in new fuel.
May 28, 2011 | Briggs & Stratton Garden
Have murray 17.5 hp ridding lawn mower after winter got new battery and when starting it ran great but the next week it when starting it it would spit alot of gas out of exhaust, had a shock from positive...
It sounds like the carburetor float might be sticking. After sitting for a winter, it could be gummed up. Shut off or stop gas flow, open the float bowl, ensure that the float has no gas in it. Next ensure that the float moves up & down smoothly. Last, hold the float up and open the gas flow to the carb, it should stop when the float is held up and start when the float is allowed to drop.
Good Luck.
Gary
May 15, 2011 | Garden
Sears Push Mower 6.0HP
Sounds like your Carberator is plugged up. Take out the main jet and clean it and be sure needle is not stuck and not allowing gas into the carb.
May 08, 2010 | Garden
My honda harmony 215 lawn mower starts but then shuts down immediately. Carb cleaner fires it up again but then dies.
most gasoline today is being blended with ethanol and is the core source of most outdoor power equipment with starting and stable running after being stored for the winter. The ethanol gums up much quicker than traditional gasoline. One product that I used was from Walmart and made by the same company that makes Stabil fuel products. It is called Start. Mix with up to 1 gallon of gas(I placed directly into my Honda Harmony 5.5 mower gas tank and ran while mowing and it cleaned the carb without having to remove it. It is running as it did when new. Worth a try
Nov 04, 2009 | Garden
Craftsman riding mower, 21hp B&S starts and dies
Fresh out of the garage says to me this is the first time you have used it this year. There is not a very long shelf life on gasoline anymore. Plus with all the additive they put in gasoline the diaphgram in the carb could have become tough and not very pliable. Kind of like paper. If this is the case have the carb cleaned and rebuilt (as in diaphragm replaced, probably needle and seat also.) Hopefully this will solve the problem.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
336 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
