Question about Dryers
My maytag performa PYET244AYW dryer will not start...any ideas?
  • Dryers Master
  • 8,220 Answers
Blown fuse due to air flow blockage. Part number LA-1053. Part location: to the right of heater mounted on heater housing. POP the top:
my maytag performa PYET244AYW dryer will not - 832b46a.jpgthe heater will be in the back.
NOTE: the fuse is heald into place on the side of the heater using the same screw that secures the heater element. Clever ain't it?
Posted on May 14, 2009
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: need to convert electrical Maytag
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Posted on Oct 16, 2011
Whamaytag performa electric dryer model number pyet244ayw does not spinm?
Drum belt failure or worn drum belt has fallen off the motor pulley or tension idler has failed or reached its limit because the belt is too loose
Sep 03, 2012 | Dryers
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
My maytag performa purchased at lowes model no PYET244AYW won't start. It ended a load yesterday and when my wife went to start a load today it does nothing. Reset breaker. Checked switch in door it...
The part called the thermal fuse is very likely going to blown due to the lint build up around the blower. To check that thermal fuse remove the wires from it and use a meter and check for continuty with zero ohms resistiance. That thermal fuse is going to be in the housing where the blower is and i have included 2 pictures it is going to be either one of the 2 shown in the pictures depending when the dryer was built which one the manufacture used at that time.
I hope i have been able to help you fix your dryer,
Aug 15, 2011 | Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Sep 30, 2009 | Maytag Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
674 people viewed this question
Top Dryers Experts
