Question about Clarion N.I.C.E. GPS Receiver
Power It only powers up when I have it connected to the car charger.
There's no battery for the unit. you must have it connected to the charger for it to work.
Posted on Oct 20, 2007
Laptop compaq will not charge will not turn on. Puting charger on it and pushing the on button i see lights once i release on button light goes out. thinking its charger or its where i plug in charger on...
Try this quick fix, if there are no issues with your charger and/or battery, this might work...
- remove battery
- make sure charger is not connected
- long press the power button for about 1 minute
- release then connect charger or power adapter, without the battery
- press power button to turn on the laptop
If this did not help, try using other power adapter.
Nov 05, 2014 | Computers & Internet
Will my Garmin Nuvi 40 work with a 24 volt supply ?
If you are using a standard Garmin car charger, you can connect the charger to a DC power source that can provide between +10VDC to +30VDC. The charger produces +5VDC to power the Nuvi. This can be verified on the charger label.
You can NOT connect any voltage higher than +5VDC directly to the Nuvi.
Apr 22, 2013 | Garmin nuvi GPS
Mains adapter for auto-xs power station not working
It could be that the internal battery is too discharged for the AC charger (as supplied with the Power Station) to work.
You could try charging the Power Station using a Vehicle (Car/Motorbike) 12 Volt battery charger, connecting the Crocodile clips on each unit.
I''ve just done that, although once 'I'd got the Power Station battery's voltage above 2 Volts, I used a 'special' charger (Optimate 5) that automatically applies several modes including 'Desulfation' for recovery.
Oct 05, 2012 | Cameras
My computer just stop now i want to turn it on it doesnt work ...my charger is still good because the indicator light burns but when i connect it to the laptop it stops burning the screen just went black...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 11, 2011 | Computers & Internet
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
Nov 30, 2010 | NRS Hoveround MPV 5 - Used Power...
My wife's Nuvi 350 will power on, start loading maps, then shut down (stays on for a total of 18 seconds). It's only 2 years old.
If its not connected to an external power source, then your battery is shot.
http://www.sharc.net/gps_battery_repair.htm
Should not do this when connected to an external power souce like the DC car charger or AC wall charger.
- Jim
Sep 07, 2010 | Garmin Nuvi 350 Car GPS Receiver
Hello my laptop isn't charging properly. It is plugged in and all of the cables are connected. There is power in the plug socket but it doesn't seem to be charging. Help!
Hi! Drain the power charges of the laptop by shutting it down and by unplugging both ac adapter (charger) and battery from the computer.
Press the power button for like 10 times while the battery and charger is disconnected to drain the power of the board.
connect back the battery first then connect the charger to the computer. Make sure that the charger is connected to a stable power outlet while charging the system.
Please leave a comment if you have any other questions.
Cheers!
Jun 10, 2010 | Computers & Internet
I have a nuvi garmin i cut the charger to connect perment
Are you sure the wires of your car have power to them? Did you use a wire for ground or did you ground it to the chassis. Try grounding it to the chassis. Some wires may only have power when the key is on or the engine is running.
Mar 05, 2010 | Garmin Nuvi 350 Car GPS Receiver
TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
GPS Logo
21 people viewed this question
Top Clarion GPS Experts
Will Halftowaite
perdue40
Are you a Clarion GPS Expert? Answer questions, earn points and help others
