Lasko 3520 20-Inch Cyclone Fan Logo
Tami Vonahsen Posted on Dec 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High pitch squealing when i turn on fan
When i turn on the fan there is a high pitch squeal.
vtec
Level 3:
Master:
  • Master 371 Answers
  • Posted on Dec 12, 2013
vtec
Master
Level 3:
Master:
Answers
371
Questions
Helped
85177
Points
1111
Bearing gone or rotor blade scraping against outer cover
1 Related Answer
Anonymous
  • 1187 Answers
  • Posted on Oct 05, 2009
SOURCE: fan blade does not immediately spin when turned on; loud
The motor bearings need machine (like sewing machine oil).
Try a quick spray of WD40 or Liquid Wrench, but use machine oil, soon.
Look for an "oil hole" on top of the motor; there may be two of them.
Heater fan was squealing and now is not turning on at all....
High pitched squealing or grinding is an indicator that the blower motor is about to die, I'd say yours has probably done just that.
2004 GMC Yukon Denali - Squealing within the interior
high pitch squeel usually comes from the cambelt
2004 trailblazer ext high beam headlights wont turn off and the relay makes high pitched noise
Need to check the ground path on the squealing relay. A poor ground will cause this condition.
4helpful
2answers
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
High pitched squeal in engine
loose fan belt?
Put the car in neutral, set the parking brake, open the hood, get someone to listen/see where the sound is coming from, as you press on the accelerator.
2answers
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Top Lasko Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
