Question about Hayward Super Pump 1 1/2 - Hp for In Ground Pools
Pump is clicking very 2 seconds and then overheats
My hayward pump is clicking very 2 seconds and then over heats
  • kv665 May 14, 2009
    turned out that when installed guy did not know what he was doing and wire was barely touching terminals. stripped wire and reconnected running fine thank for your help
    Scholar:
  • 42 Answers
I'd say you have a problem. The clicking sound is likely a thermal overload from too much current being drawn and the temp rising.
Once it cools off a little it tries again; draws too much currrent, heats up and the thermal overload kicks it off again.
It could blow the breaker as well, it just hasn't yet. Probably because there isn't a short circuit, just thermal overload from too much current for too long. It's a built in safety device internal to the pump motor.
My guess is the pump is bad -- and either the impellers are shot or a bearing is bad.
It would be nice if you could manually turn the pump shaft and see if it feels stiff or it makes unusual grinding noises, but you probably can't get to it.
I'd also guess that a pump repair is not cost effective, 'cause if the pump is that worn, fixing it will only keep it going 'till the next odd-ball thing goes wrong with it.
good luck
Posted on May 13, 2009
  • xenophanes May 14, 2009
    It is very good that you found this problem. An arcing wire, if it goes long enough will result in a large spark and possibly a fire.
    I have run across two dryers with badly fastened wires, and both of them had burnt wiring that had to be replaced.
    congrats!
    congrats!
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
PUMP RUNS A FEW SECONDS THEN CLICKS OFF
Verify that your voltage is correct, then check your amps. It sounds like you have a short in the windings causing the motor to overheat. This usually mean replacement. (the repair would be almost as much as a new motor)
Feb 07, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
There was a freeze recently that busted my pipes. i fixed the pvc and tried to turn the pump on and nothing happens, silence.... The breakers are on amd the polaris booster pump works... however the 1.5 hp...
1. Is there a switch on the bottom of the pump?
2. Hearing nothing indicates no electricity to the pump.
3. Is there some other location where power could be off or tripped off?
Gary
Feb 21, 2011 | Hayward Pool & Spa
My hayward super II pump is cycling between hign and low speed every i second until it overheats and shuts off. What could be the problem
VOLTAGE IS SET FOR 230 AND YOU ARE RUNNING IT ON 120V BACK OF THE MOTOR HAS A WAY TO SET THE VOLTAGE.LOOK ON TOP OF THE MOTOR FOR THE WIRING SCHEMATIC . THERE IS A START AND RUN SPEED.. HOPE THIS HELPS VOTE Jay
Jan 30, 2011 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Is there an advantage to a 2 speed over a regular 1.5 Hayward motor?
It cost's more and thats it unless you have the switching to run it. If so you can use low speed to clean and heat to save money on your elect. bill.
Jun 25, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
New hayward 1 HP super pump runs 1 or 2 seconds, then shuts off. After 1 or 2 minutes, will come on for 1 or 2 seconds, then shuts off again
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Jul 04, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward Heat Pro Electric won't stay running
from the Hayward support site....
Why is my pump cutting off and on every 5-10 seconds?
  • Hayward motors are factory wired for 240 volts unless the motor is 120 volts ONLY. Check the voltage of the incoming supply power and ensure the motor is wired or can be wired for this voltage (data plate on motor will help provide voltage and wiring information). Also check for loose or badly connected wires. Contact a certified electrician for repair.
Sep 24, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Hayward Super Pump 1 1/2 - Hp for In Ground Pools Logo
362 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
