Failure to switch on
My 29 inch phillips TV switched off suddenly and fails to switch on again despite repeated attempts.
    An expert who has answered 500 questions.
  • 556 Answers
Fails to switch on again despite repeated attempts.
this is due to power supply failure.
please call skilled tech to fix it.
Posted on Oct 15, 2007
Lg 29 inch flat tv golden eye is power off he dont start
Possible failure of the SMPS power supply. Please check the fuse and switch after disconnecting and checking the circuit.
Feb 21, 2011 | Televison & Video
The main power supply failure when switch on the TV
Pl. check main fuse of your house any loose contact may fail your mains power supply,as there is heavy current drawn as you switch on TV set for few seconds.If the mains fuse is o.k than there may be direct shorting inside the TV set,call expert technician to rectify the same.
Jan 15, 2011 | JVC AV-F29MX3U 29" TV
Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Apr 13, 2009 | Philips Magnavox 42MF521D/37 Television
Tv switches itself on and off no picture
Just had this happen to me. It's caused by a failure of the power supply board. Replacing the power supply should fix this issue.
This appears to be a very comon problem.
Mar 25, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
No audio is coming at all in my philips 29 inch Hi-fy tv.
If you have a provider box it also has a volume control,manully turn your tv up and use your controller to turn the box up.
let me know
Jan 30, 2009 | Philips HI-296 Iron
Does not get switched on
yes possibal but send me amore deatil of your laptop configuration ................
becuase the we have provid the quotaion for laptop but .....fist of we have no idea about with part you have upgarade .........send me online foam
Jan 07, 2009 | Dell Inspiron 7000/7500
Phillips 29" TV
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Feb 13, 2008 | Philips 27PT6441 27" TV
Sony TV kv29LS60e - over voltage protection
it is power supply problem. your oscillator for switching ckt or switching output failure. if you are not tech person call him for help. it is not a major problem good luck.
Oct 02, 2007 | Sony KV-29LS60 29" TV
TV Akai CT29X4AV
Have tried checking if the Power Plug is fitting tightly in the Power socket? Could be that it is loose?
May 27, 2007 | Akai CTS2550 25" TV
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
