Question about Lexmark X3550 All-In-One Printer
Paper jammed part way
When printing, the paper goes about 1/2 way, and then scrunches in the center of the paper and then wont go any further. Then it says paper jammed, but really the paper never even got far enough in to be printed on.
    Sergeant:
    Champion:
  • 240 Answers
Try to unplug your printer and restart your computer..
Posted on May 13, 2009
How to fix paper jam when printing 2 sided
make sure all rollers and rollers are clean us alcohol sparely and make sure you use quality paper also it does make a difference
Apr 07, 2016 | HP CM749A - Officejet Pro 8600...
Why is the paper on my printer going through the back and coming out instead of printing?
there is a rear door on this printer if it is removed while clearing a paper jam and not placed back after the paper jam is fixed it would push paper straight out the back of the printer. It could have a paper jam also at the rear of the printer. Recommend checking rear door of printer and also check at this location if paper is scrunched up and causing a jam.
May 29, 2014 | HP Photosmart D110a Wireless E-all-in-one...
My dell printer shows error after I have cleared the paper jam.
Try and check the ink or maybe the paper is scrunched up smooth them out.. If this doesnt work then sorry this all i can do XD
Apr 04, 2013 | Dell 1250c Color LED Laser-Class Printer...
A HP Color Laserjet 3000n has the following errors and will not print: 13.20.00 Jam Inside Front Door 13.20.00 Fuser Jam Inside Top Cover Error messages switch back and forth. I have checked for paper in...
Perry,
Usually I have found that there is a scrunched up piece or bit of paper in the fuser.
I am adding a link below that will take you through the step-by-step process and you should find the source of the problem. Be careful when touching the fuser that thing gets HOT!!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506722
Please let me know if this has helped and if i can help you any further.
Thanks
Mar 31, 2011 | HP Office Equipment & Supplies
Each time the printer goes to print the paper
Either you have a problem with the fuser itself, such as a drive gear problem where the fuser is not turning or the is toner buildup on the fuser entrance plate. The toner buildup is a common problem so I would check that first. The fuser is easy to remove and you just beed to flip it over and look closely at the plates that "guide" the paper into the fuser rollers. Look for any small globs of melted toner that the paper is hitting when it tries to enter the fuser. If you let it cool down first then the toner can usually be chipped away and scraped clean. Then just reinstall.
Good Luck.
Mar 04, 2010 | HP LaserJet 4650n Printer
While printing, paper jams. the sheet pulls through initially, but then while printing, the paper scrunches up and the cartridge jams.
It is likely that there is a small piece of torn paper inside that is causing the paper to bunch up. Try a can of compressed air to clean out the interior and trace through the route the paper takes. Look for anything the paper could get stuck on.
Good Luck!
Nov 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam on canon pixma mp600
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper jams sideways and gets munched up - will not print
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Oct 25, 2008 | Dell 922 All-In-One InkJet Printer
Paper Jam at exit
This happened with an old HP Laserjet 1100A of mine.
I had apparently dropped a screw in the paper-out slot and it was jamming the paper on just one spot.
As you know, the entire sheet is connected, so It is most likely a similar situation in which a previous jam has left a small wad of paper under one of the rollers, and this is preventing the paper from exiting the slot.
Best bet, print something and see where the paper is scrunching up. This is most likely the roller that has the paper stuck under it. Remove the toner block and blast some compressed air into the spot the jam is most likely originating and see if anything else flys out.
Also, if that does not work, you might try manually rotating the rollers backwards, which will often eject the lodged paper chunk.
Note- Please be careful inside the printer! Do not touch the bright green drum, or anything that dosen't look like it is rubber and rolls paper around!
It is very easy to mess things up in there ;)
Sep 28, 2008 | Samsung CLP 300 Laser Printer
Printer screen tells me that there is a paper jam - no paper left in printer
Check rear door, it comes off, and also look to left and right sides of carriage paper gets scrunched into sides by head.
Dec 25, 2007 | Brother MFC 240C All-In-One InkJet Printer
Lexmark X3550 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
