DVD doesn't always read
I have a player that doesn't always read the disk.  Sometimes it locks up, skips, or says the disk is not readable.  It doesn't matter what the age of the disk is.  It won't read the newest one, but will read some copies.  A cleaner was used, then the machine was opened to check for dirt, etc..  Any suggestions?
Thanks, Lisa
  • 4 more comments
  • Sanchez14305 Nov 27, 2007
    I have the same problem. The DVD will play sometimes and when it does it will skip a bunch of times in the beginning of the DVD. The DVD can be new or old and it won't play. I cleaned the lenses with water then wiped it dry. Please help.
  • vidboy Feb 02, 2008
    My LG DN191H does the same thing. LG phone support said it is likely the lens. Of course it is jus tone month past the end of the warranty.
  • thesheki Feb 10, 2008
    I had the same problem with DVDs not reading, skipping, etc. I sent the unit in for repair and a new optical sensor was installed. Less than two months later it started doing the same thing, and another optical sensor was installed (under the 90 day service warranty). Less than three months later it is now doing the same thing. We don't use this DVD player that much, either.
    There is something very defective in this high-end player, and I would really appreciate finding a lasting solution.
    Kirk
  • Anonymous Jun 04, 2008
    MPD845 Magnavox. Won't read the dvd. says that it is loading and then no disc.
  • Anonymous Jul 01, 2008
    When a disc is inserted it just says loading for a few seconds and then says no disc
  • Anonymous Nov 12, 2008
    doesnt read the disk
I switched to Juji disks, rare to have the problem now unless power failed with disk in drive then its toast. Will not even reformat. I now erase in my PC drive then reformat and it's back. Of course the content is lost.
Posted on Jul 05, 2008
Mine does the same thing. It will "lock up" when playing a movie. It only started last month, when it was less than 9 months old.
Posted on Feb 02, 2008
TAKE IT BACK!!! I got one and that happened so I took it back and got another one-same problem, THERE JUNK!
Posted on Dec 07, 2007
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
No read this disc
Cd or DVD could be an unsupported type of disk some can (CD-Rw, DVD+/DVD-, the format the data is in may not be readable ( Mp3, WMF, AAC) , or it could possibly be a disk with another country's reign code ( foreign disks can cause disk incompatibility.
Aug 22, 2012 | NAD T585 DVD Player
Dvd/cd rom can't read dvd
Sometimes you just need to clean the disk or the dvd head on your player. If this doesn't work the disk is of the incorrect format.
Jul 29, 2012 | HP Computers & Internet
I just burend a audio cd but it wont play on my cd player
Just a tip.
You can try to burn an CD at a lower speed.
So the index will be deeper and better readable for a normal CD-player.
Ragards,
Gerard
Feb 01, 2010 | NAD L40 CD Player
When Palying a CD Music skips (Media Player)
Greetings my friend, regarding on your problem try to check or clean your CD/DVD ROM. Try to clean it with disk cleaner cause sometimes we forgot to cleam the important part of CD/DVD ROM its eye the one that reads all the dat in the disk. So try to clean it and play the disk again after you clean. Also try to clean also the disk you want to insert in your CD/DVD ROM in order to prevent this problem again.
Jun 16, 2009 | Computers & Internet
NO DISK
Unit may have defective optical pick-up. Or make sure disk is not in up side down. Or it may have processor lock up -- unplug for 24 hours
Apr 21, 2008 | LG DN191H DVD Player
DVDM 1805
it sounds like you might need to clean the laser eye, try that and get back with me
Dec 10, 2007 | Denon DVM-1805 DVD Player
Check disc
Is the surface or your disk smudged or damaged? If not, try a lens cleaner CD or kit and see if the problem goes away. If they are DVD Rs or something similar(DVD-RAM, DVD+R, ETC) the player may not be able to play that particular format, and you should double check the instruction manual to see what types of disks can be read.
Nov 08, 2007 | Sony DVP-FX810 Portable DVD Player
Cd dvd wont play
Many of the older DVD and CD players will not play disks recorded on a computer. This has to do mainly with the laser optical response.
There were several manufactures that manufactured their laser unit with a built in filter that would not allow their player to read non pressed CD disks (disks burned with a home computer).
When buring DVD's or CD's, use the slowest possible speed for the burn to have the highest readablity and least data errors possible for the medium.
Jerry G.
Mar 09, 2007 | JVC KD-AVX1 Car DVD Player
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
