Question about Microsoft Xbox 360 Console
Xbox live i got randomlly signed out of xbox live. i've tried to log back on wont let me, i did a troubleshoot for the xbox live and everything is confirmed but when it gets to XBOX LIVE it says fails i dont understand what happend someone help plz?
  • 23 Answers
THINGS TO TRY loadTOCNode(1, 'whattotry'); Direct connection with a modem only loadTOCNode(3, 'whattotry'); 1. If you are connecting to Xbox Live by using a modem that is connected directly into your broadband socket, your IP address settings are obtained from your ISP. Set your IP address in Network Settings to Automatic. 2. If you use a static IP address that you obtained from your ISP, you must manually enter this address in the Dashboard. Contact your ISP for their static IP address if you do not know it. If the IP is not static, continue with the rest of the troubleshooting. 3. Power cycle the modem. 4. If your ISP requires PPPoE settings, verify that you have entered them correctly. 5. If your ISP does not use PPPoE authentication, do not use these fields in the Dashboard. Shared connection with a modem and a router loadTOCNode(3, 'whattotry'); 1. Power cycle both the modem and the router. 2. Try connecting the Xbox 360 console to Xbox Live by using the modem only. This eliminates any configuration problems on the router. • If this setup works without the router, there is a configuration issue with the router. See the router's documentation or contact the technical support group. 3. Verify that your router's DHCP service has been enabled. See the router's documentation or contact the technical support group. 4. The IP address that you entered in the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If your ISP requires PPPoE settings, try to connect with only the modem after you enter the PPPoE settings in Network Settings. • If you can connect, see your router documentation to configure the PPPoE settings correctly on the router. 6. If you are receiving an IP conflict error in the More Info section, turn off all the devices on the network. Try to connect with only the modem and Xbox 360 console connected. • If this works, there is a configuration issue on the routers DHCP server. See the router's documentation or contact the technical support group. Shared connection with a gateway device (combined modem and router) loadTOCNode(3, 'whattotry'); 1. Make sure that the device is turned on. 2. Verify that there is activity with the blinking lights sequence WAN, ADSL, and Internet connected power. Note These names will vary from model to model. 3. Power cycle the gateway device. 4. The IP address that you entered in to the Network Settings area of the Xbox Dashboard may be incorrect. Set your IP settings to Automatic. 5. If you are receiving an IP conflict error in the More Info section, turn off all the other devices on the network. Try to connect with only the Xbox 360 console on the network. • If this test works, there is a configuration issue on the gateway DHCP server. See the router's documentation or contact the technical support group. Shared connection with Microsoft Windows Internet Connection Sharing loadTOCNode(3, 'whattotry'); 1. Verify that you can browse the Internet. If you cannot browse the Internet, Internet Connection Sharing is not configured correctly. 2. Power cycle the modem. If the modem does not have an on and off switch, unplug the modem from the power outlet. You cannot follow this step if you are using a USB modem. Instead, go to the next step. You must follow this step if you are switching the modem between the Xbox 360 console and a computer. 3. On the computer, click Start, click Run, type ncpa.cpl, and then click OK. 4. On the View menu, click Tiles. 5. If the connection is listed as Firewalled, the firewall may have to be configured. See your firewall documentation. 6. Enter manual settings in the Dashboard for IP address, subnet mask, DNS address and gateway: • IP Address : 192.168.0.2 • Subnet mask : 255.255.255.0 • Default Gateway : 192.168.0.1 • DNS server (Primary): 192.168.0.1 • DNS server (Secondary): 192.168.0.1If none of this works you might be banned. If you modded your xbox360 or for downloading game saves from the internet to boost you gamer score. You might be banned!
Posted on Oct 17, 2007
  • McloveN Oct 17, 2007
    wow thats a mess lol sorry bout that i copied and pasted that.
    Here this is cleaner http://support.microsoft.com/kb/908885
How do I sign up for an xbox live account? Account suspended?
i think you can find here the solution http://forums.xbox.com/xbox_support/xbox_360_support/f/9/t/1533907.aspx
Dec 25, 2015 | Xbox LIVE
I tried to sign into xbox live and it says a problem occurred. and it said to come to this website. what do i do?
You may have a problem with your internet connection. Try and reset your router and try again.
May 03, 2011 | Microsoft Xbox 360 Console
It wont sign in to xbox live
Try unplugging you router for about 30 seconds, and then plugging it back in.
May 15, 2010 | Microsoft Xbox Console
HOw to you logon to EA sports through xbox live console. System telling i must be logon to play but doesn't give me a spot to log on..help..
It will sign into EA's online service automatically with your Xbox Live account. This applies to all games that sign into an EA server.
Feb 25, 2009 | Microsoft Xbox 360 Console
Xbox live
I would suggest that if you are xbox live unless you have fast internet dont use the internet for other things like your computer. Its most likely that there is not enough bandwidth for everything. If that doesnt work call you internet service provider and explain the problem to them and if they are a legitamate company they will help you out.
Apr 10, 2008 | Microsoft Xbox 360 Console
Xbox 360 wont connect xbox live
Your xbox live membership may have run out. i had the same problem yesterday as mine had expired. The automatic renewal had not taken place as my credit card details were out of date.
You can check your xbox membership status via your PC at xbox.com. log in woith your email address and password you supplied at the time you initially joined xbox live.
Dec 23, 2007 | Microsoft Xbox 360 Console
Xbox live
hi ppl,
Check the codes on xbox live more info panel pay particular attention to the z code. At the moment I am getting Z - 0000-0000 which is fine it just means that xbox live servers are down however if you have the codes 8015-190D I'm afraid you have been banned however don't shoot the messenger please.
We're all not connecting at the moment.
Pain in the a
IS THIS STILL GOING ON?
Oct 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
166 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
