Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Wire off around door
THe wire around washer door came off. What is te best way to get wier back on te door? Thanks, Roger
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine and the best way to get wier back on te door.
we have al bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 05, 2013
  • 323 Answers
If you are talking about the tension wire in the rubber gasket that seals the door, the best way is to use someting blunt, like a wooden ruler, and make sure it is properly placed inside the seal. Then start at a top corner and slowly push it bacl over the lip. It helps to have a second person hold what is aready pushed over the lip so it will not continue to slip off. If this is not your problem, please writte us back and give a little more information.
Sirwriter
Posted on May 13, 2009
Door lock error
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 25, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer 2005. lights flashing, door locked, sounds like it is turning but it is not moving...can we reset--how? thanks
1. Unplug washer.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Dec 19, 2009 | Kenmore Elite 45986 Front Load Washer
2001 grand am se 4 door and want to put 2 12inch subs in it i have te subs and the amp i also have te wiering do i need to buy a new deck or will the one i have work?
The one you have will work but an aftermarket one would work better. You will get more output out of an aftermarket deck.
Nov 09, 2009 | 2001 Pontiac Grand Am SE
My washer wont start.
FDL error = Function Door Lock Error
1. Unplug washer.
Thanks for using FixYa -a Very Helpful Rating is appreciated for answering your FREE question.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Upside down F and E error message any ideas?
would that look like a tE or dE? TE is Thermistor error. Replace thermistor and check wiring back to control board. thermistor is accessible from bottom of unit reaching up to bottom front of tub. in middle of heater element it just pulls out of rubber seal.
DE would be a door error. is door open or did it lock when cycle started. door lock asm should fix this.
Jul 05, 2009 | LG WM-2277HW Front Load Washer
I have a LG LDF6810ST dishwasher with a tE error code. The service manual says check the wiring, the thermistor, and as a last resort, replace the main PCB. Where is the thermistor? Can I check the...
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
May 06, 2009 | LG LDF6810ST Stainless Steel Built-in...
How to remove door switch--Kenmore HE2 Plus??
1. Unplug washer.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Apr 10, 2009 | Kenmore Elite 45986 Front Load Washer
LG washer tE error code
A "tE" error code is more than likely the "thermistor". Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place.
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
