Question about Danby 22 in. DDW399 Free-standing Dishwasher
DDW399D Dishwasher For some reason the pray are is not working. It is not shooting the water up as it should be. I was wondering if there's something I can do to solve the problem.
    New Friend:
  • 11 Answers
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
My complete repair instructions including a link to pictures can be found here:
http://www.megaupload.com/?d=XBOGBR4I
Posted on Jul 27, 2008
  • 3 more comments
  • John Charles Mar 24, 2012
    hi mitch. from the sound of it, i'm experiencing the exact same problem, and your instructions sound very useful. however, megaupload has been shut down by the government. is there another means through which i could access the instructions? thanks.
  • Mitch Rapp Mar 24, 2012
    Megaupload has been taken down. So I uploaded my instructions to Rapidshare:https://rapidshare.com/files/2513382893/...
    Rapidshare removes files if not downloaded within 90 days, so if the link does not work, post a comment, and I will reupload.
    Mitch Rapp
  • Ally Tate Nov 30, 2012
    Hello! I'm having the same problems, but it's unfortunately been over 90 days. Would you mind sharing your solution again? Thanks!
  • Mitch Rapp Nov 30, 2012
    Sorry about the dead link. Stupid Rapidshare. Here is a new link. Hope it helpshttp://rapidshare.com/files/2061037156/Danby%20Dishwasher%20DDW399W%20repair%20info.doc
    Here it is again: http://rapidshare.com/files/2061037156/D...
    Problem Solver:
  • 9 Answers
Check and make sure that there is nothing blocking the pump inlet underneath the mesh removable filter. It should be making a whirring sound like it's trying to pull water in in a cycle. If it's not making that noise your pump is shot.
Posted on May 13, 2008
Frigidaire dishwasher is not spraying water from bottom
From what you have described, sounds like the sprayer arms are possibly loose or being held into place and can't rotate, by dishware.
Aug 07, 2012 | Electrolux Frigidaire Professional Series...
I replaced a disposal and now when I run the washer cycle the used water shoots out the drain that is on top of the sink. It didn't shoot out that drain while the old disposal was working and the dishes...
The new disposer has a plug inside the dishwasher nipple that you must knock out. The dishwasher hose nipple is plugged so water won't leak out if you don't have a dishwasher connected. You must take a flathead screwdrivers and knock out the plug inside the nipple with a hammer or something. Make sure you don't leave the plug inside! The air gap is designed to prevent water from siphoning back into the dishwasher. With the disposal's drain connection blocked, the water exits through the air gap!
Feb 15, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher has worked great for 2 years, now all the sudden it won't empty the water, How can I trouble shoot it to find the problem?
things work till they don't / so look for a drain pump failure or something in drain line ( very common ) if you have just replaced the disposal you need to remove the plug for the dish inlet .. it's a knock out .. mm
Nov 20, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
My Miele dishwasher is stopping and reading
buy another one or contact to there shop thanks
Apr 13, 2009 | Dishwashers
Water won't come in
Cynthia,
There's a flood/safety switch in the dishwasher. It's there to monitor the water level. It does this by rising as the water rises... if it gets too high, it'll shut the water off.
Open the door and remove the lower rack. You'll see it right there in front. Lift and drop it several times to clear any debris. (In order for the dishwasher to get water, it has to be all the way down.) Now try your dishwasher.
SG
Mar 27, 2009 | Kenmore Dishwashers
Dishwasher arms not spinning
you can try to remove hte lower spary arm, and access the sump assy under the filter plate( torx 15) screws, and afterthe op is reved 2 mose screws underhter will gain oyou acesss to the choper/ screen area. make sure if claened out.after reaasembly it still has no pressure to spray arms you nned to repalca seal/ impeller kit for motor. 8531017. not to terrible difficult to install, you will need to remove the motor assy to do it though
Mar 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Hygena Dishwasher doesn't fill with water
Sorry that is a UK model and wont have any access on how it works.. but you can check the water level probe (if Equipted) clean it off.......... the elements should only come on once the probe tells the board it has water dont let the element dry fire they will burn out fast when not in water
Feb 04, 2008 | Dishwashers
Kenmore dishwasher 15762
On the inside of the dishwasher (on the bottom), there should be a little "float" device, which tells the dishwasher when it has put enough water into the tub. Sometimes, this float gets stuck in the "up" position, so the dishwasher never puts any water in, but continues to run anyway as if it did. Try pushing down on the float to unstick it, then start the cycle over and see if it puts any water in.
Feb 06, 2007 | Kenmore 15762 Dishwasher
Danby 22 in. DDW399 Free-standing Dishwasher Logo
406 people viewed this question
Top Danby Dishwashers Experts
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
