Question about RCA F25216BC 25" TV
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Manual Menu button on RCA model F25216BC is not working. After I did a auto channel search from the set Menu button, I attempted to manually add another channel. That is when it locked up and only one channel will now show. I do not have the original RCA remote. I am using a DirecTV remote. The set is no longer connected to DirecTV. I can get other channels by entering the number of the channel on the remote. Would the problem somehow be parental lock and if so is it possible to remove this without the original remote?? Please inform me of any cost for your help prior to assistance. Thank you.
  • 4 Answers
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
Posted on May 13, 2009
I am trying to program the RCA ColorTrak Plus TV to my satellite receiver and I get nothing but snow
You will need to get a "regular" Universal remote and program it for that particular model of TV. You will need to access the on screen setup menu for the TV and then have it scan the channels. Make sure your DTV box is on and connected with the coaxial cable. If the "TV Input" button on your DTV remote works and you can get it onto the Video Channel, You can connect your DTV receiver with the RCA Cables (Red, White and Yellow) and get your picture that way. If you access the on screen menu, you will need to scan for Analog and Digital channels as the receiver transmits in Analog. hope this helps.
Sep 24, 2012 | Televison & Video
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
Cannot program channels into remote
IF YOU, STILL SUBSCRIBE DIRECTV, YOU MAY GO TO THE MENU, USING THEIR CLICKER AND GO TO THE PART OF MENU, WHERE YOU CAN CHOOSE TV TO OPERATE WITH DIRECTV REMOTE. YOU WON'T BE ABLE TO CHANGE ANYTHING ON TV BY USE DIRECTV REMOTE, BUT TO OPERATE IT'S CONTROL BOX. REALLY, YOU CHANGING CHANNELS ON THAT BOX, NOT TV ITSELF. IF YOU'RE NOT A SUBSCRIBER, FORGET THAT REMOTE! UNLESS YOU'RE A CUSTOMER, IT WON'T HAPPEN. JUST "GOOGLE" YOUR MAKE AND MODEL FOR A SUITABLE UNIVERSAL REMOTE, OR THE ORIGINAL.
ALSO: YOU WON'T BE ABLE TO GET ANY RECEPTION(HD OR ANY), UNLESS YOU HAVE RABBIT EARS OR ANTENNA ON A ROOF.
GOOD LUCK,
ALEX'S TV.
Apr 06, 2010 | Protron PLTV-32 Television
Codes not working, need to bring up menu on tv
Yes , Most Rca will not work so you need something that has more codes, Let me give you a website to checkout www.remotes.com, These people will not only help you but they will find a remote that will work for your TV, Give them a call as well they do have codes and remotes for all TV's you be happy you did. Do not shoot the messanger give a good rating.
Jul 10, 2009 | Universal Remote Control DIRECTV Universal...
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Dec 02, 2008 | RCA DIRECTV Satellite Remote Control
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Televison & Video Logo
219 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
