Question about Bosch 24 in. SHU43 Built-in Dishwasher
Door Tension How does one adjust the door tension on a SHU43 model dishwasher? The door opens up all the way with no tension from the springs/cables.
  • kkwales Nov 14, 2007
    the door on my built in bosch dishwasher will not close tight to perform a wash. How can I repair it? Checked the door hinges look fine we think its the hook at to which won't connect
  • 209 Answers
Just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
Why does door open too far and is not horizontal to the floor when open?
Besides spring streaches out over time or one rope breaks. Their are like three spots to hook spring to get tension for door. I just replaces both ropes as one broke and hooked springs in middle hole. Takes more time to pull washer out then to replace the ropes
Oct 31, 2015 | LG LDF6810ST Stainless Steel Built-in...
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
What could be causing the door latch to release late in the wash cycle of my Kenmore Ultra dishwasher?
The door spring tension might be causing the door latch to become disengaged. Check the level of the dishwasher and also adjust door spring tension. Will need model number to provide more details.
Jul 31, 2014 | Kenmore Dishwashers
Door hinge tension adjustment
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
Sep 05, 2013 | Bosch Dishwashers
Apparently the springs on my door are either not connected or they need to be adjusted. If I were to open the door and not hold it with my hands, it would immedaitely fall wide open. No tension exists on...
I had the same problem on my Dishwasher . There should be 2 screws underneath the top front part of the dishwasher. They hold the unit in place. Easy to get to. Open the door and look up. Pull out the 2 screws that are screwed into the underneath of the front cabinet.
This should allow you to pull (slide) out the unit just enough to see the springs ( aprox 1 ft ) on both sides on the bottom of unit. Inspect the springs. Mine had broke on one side where it clips into the holder.
I just inserted the spring in the proper tension hole to match the other side . I spun it around 1 turn as to hold it in place and then connected the top of spring it its proper place. This gave equal tension on both springs and the door works fine now.
Eventually I will buy a new spring and replace it but at least it works fine for now.
If even one spring has been disconnected the door will fall with out any tension what so ever. I'm guessing maybe just one spring has either come out or broke where it clips into the hole.
Aug 30, 2010 | Frigidaire FDB520RHS Full Console...
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
497 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
