Question about NetGear WGR614 Router
Wireless adapter on 2nd computer is not connecting to my router
I have 2 computers...the Netgear WGR614 Router v9 that is on my main computer is working fine, and is connecting to the internet just fine, but the 2nd computer that has the Belkin adapter on it, is no longer connecting to my router. How do I fix this so that the 2nd computer will connect to the internet?
  • 611 Answers
You put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
Posted on May 14, 2009
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I have a Netgear Wireless G WGR614 v9 Router. I
It seems that your Internet download is fine but the issue is with the uploading. Try to switch of the router for few min. Remove all the cables out and press the Power button for 10 to 15 sec and replug the cables
Check the internet connection.
Check connecting to the face book or other web pages abd try uploading the small image first, If its not working .check the upload and download speed www.speedtest.net. and complaint to ISP to increase the Bandwidth
Check the bu
Jun 03, 2010 | NetGear WGR614 Wireless Router
Link the netgear wgr614v10 to linksys wireless adapter
First you will need to check the wireless settings of the router. Do you have any computer connected to the router ? If not then connect the computer to the router and open the set up page of the router, check the wireless settings of the router.
Once you have all the wireless settings of the router then you can try to connect to the wireless network on your wireless computer.
Apr 17, 2010 | NetGear WGR614 Wireless Router
I just installed netgear wireless-g router WGR614 on my main pc modem with i have internet service with Clear. HOW DO I GET INTERNET SERVICE ON MY OTHER COMPUTER WHICH ALSO IS A DESKTOP? i CONNECTED A CORD...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Need network key for NETGEAR (virgin) to connect
for that you have to access your router.
connect your router to computer with ehternet cable.
then access it with following link.
http://192.168.1.1
or http://192.168.0.1
type user as 'admin' and password as "admin" or blank or 'password'
then go to wireless security then you find WEP or WAP key there but it is in * or # format so you can't know it.
So you have to set new key so you can easily know it.
Then set new network key then save and restart the router then you can connect it with new key.
Aug 22, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Accidentally unplugged our WGR614 v9 netgear router and now my other computer and xbox 360 will not pick up the wireless network anymore
yup its possible that the configuration on the wireless networking adapter, was like removed..
just configure it again..
Dec 01, 2008 | NetGear WGR614 Router
NetGear WGR614 Router Logo
251 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
