3 amp fuse blowing in York central A/c
3 Amp fuse kept blowing, wouldn't allow fan to work. After replacing fuse fan works, but when I tried to put the switch to cooling on thermostat it popped the 3 amp fuse again. Replaced fuse again and ran fan all night switched thermostat back to cooling (on accident) but now the a/c works. I 've been having to service the a/c unit with freon for the past 2 years, usually the servicing last for a year before I have to do it again...... I have a small leak. Other than the leak should I be concerned about anything? Why did it initially blow the fuse when I replaced it and put the a/c on?; then after a night of running the fan by itself the unit started working? Thanks for your help,
    President:
  • 3,433 Answers
Hope things are working for you now. In any case, Keep a couple of things in mind. The control (thermostat) is low voltage.A not so simple,simple switch that obviously senses ambient temperature and at a preset time will Or temp will switch on a secondary relay closing a high voltage circuit to drive the fan motor. The fuse that keeps popping is a very light fuse, it won't take very muchas far as a loaded circuit on demand. depending on when the fuse pops makes a difference. Instantly, over a period of time, when the thermostat attempts to start the fan,etc. A short or overload? A short circuit is virtually instant at taking out a fuse. An overload is a wee bit slower. Not knowing the time factor for the fuse to pop,I stab at the overload possibility. The fan relay may be wornn and or binding when called upon by the Stat to actuatethe fan relay.A short? All you can do is make sure the wiring has not been re-arranged or in contact with anything besides the terminals they. belong on.
TAKE HEED!!! lOW VOLTAGE CAN TICKLE YOU. hIGH VOLTAGE CAN AND MORE LIKELY WILL KILL YOU. SO, Be with care around the relays. Good Luck.--- Ned
The refrigerant leak should be located and repaired. That stuff is Gold these days. I've found most leaks are on the outside condensor unit at the fitting connecting the unit to the house. The condensor often gets bumped by lawwnmowers and people leaning on them. Look for traces of oil at all the connections you can get to. It's a sign of possible leakage.The system is under pressure so againwe ask care be taken when tughtening any fittings.It's all yours now. Unless you have an a/c tech you want to work with. One more biggy. The EPA requires a certified Technician uf your systen as to be opened.
Freon Loves to eat our atmosphere. Let me know iif this has helped ir not. Thanks---- Ned
Posted on Jul 09, 2013
  • 83 Answers
A blown fuse is a sign of a short circuit. either connections are touching each other or a relay is busted. Have it checked. Have the system leak checked also, this would result to better cooling/heating and energy savings.
Posted on May 13, 2009
2005 cobalt put new radiator fan on still blows fuse even if the fan is not pluged in just hopeing someone had same problem with theirs
If you had a 5 amp fuse and fan draws 3 amps all is good.
BUT, if there is a short circuit before the fan, it will blow the fuse.
Check the wiring is not chaffed or worn between fuse box and fan, or switch to fan.
Feb 13, 2015 | 2005 Chevrolet Cobalt
How can i get a replacement 5 amp 125 volt fuse for a holmes twin widow fan
It's worth noting here that it's more about the physical size & shape of the Fuse thats needed to fit your Fan.
You don't have to use exactly a 5 amp @ 125v fuse.
Any fuse that Fits and is in the range of 5,6,7,8,10 Amp and even 230v is ok.
The fuse is like a piece of soft metal that will melt if too much current is being drawn by the device. The Amps & Volts only define approximately when the fuse link will melt (blow). But as the fan gets dirty and older the LOAD it draws might get slightly higher. Enough to cause the fuse to slowly melt. So a small to 6, 8, or 10 Amp should work just fine. A wiring short will still cause the 10 Amp fuse to blow thereby keeping things safe. The manufacturer uses a fuse that fits in the space he has allocated & allows the unit to run continuously without blowing on a slight load.
But it is only a safety device to protect the device from internal shorts.
It stops a shorted motor or shorted internal wiring from getting too hot and possibly causing a fire.
But a 20 or 30Amp fuse would still blow if it is shorted.
For example...If the 5 A fuse keeps blowing then you could try say an 8 or 10 Amp fuse. If that blows then their is definitely a problem with the circuit. Don't put anything larger than 10 Amp in.
It then needs to be looked at by a service technician.
The voltage rating on a household fuse isn't that critical.
It's actually the wattage it takes to melt the fuse link. It's based on the mathematics of Ohms Law (Watts =Volts x Amps)
But thats another story....
Cheers
Trevor
Jul 16, 2014 | Holmes Products Dryers
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
AC and Cooling Fans Not Working
Try installing a jumper across the N/O terminal at the relay socket. Temp sensor in the radiator or in the thermostat housing supplies the signal for the relay the other relay signal is supplied by A/C in on position. both fans will run continuous with A/C on. One fan runs intermittent relative to water temp. Be careful not to blow a head gasket. If you leave the jumpers in place, the fans will stop when the ignition is turned off, save the engine until you isolate the relay signal problem. then simply remove jumpers and reinstall the relays
Feb 28, 2017 | 1989 Toyota Camry
Central air blows 3amp fuse
Hello, check the thermostat wiring between the indoor unit and outiside unit and make sure it is secure. Also check the contactor coil on the outside unit and make sure none of the wires are loose and touching metal. You csn also unhook the wires and put them back one at a time and see which one blows the fuse.
Jul 10, 2012 | Goodman Heating & Cooling
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
Blower fan starts fine sometimes circulating fan starts right away then after about 4 0r 5 min the small 3 amp fuse blows and shuts down whole unit. What is this fuse for and why does circulating fan...
Hi WFO9, It sounds as though the fan capacitor is under specs. It is probably losing its capacitance ability, they are usually rated plus or minus 5% of the value printed on the case. If however the capacitor is no longer within the rated specs. the fan motor will draw too much current and will then blow the fuse. either that or after the normal start delay built into the Ac, which is 3-4 minutes, the compressor tries to start and again draws to much current and blows the fuse. have all the capacitors checked and replaced if they dont meet the specs printed on the capacitor case. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
System not working when switched on.Observed 3 amp fuse blown. Replaced with 13 amp fuse and switched to manual. Sparks and noise coming from one motor. ? brushes or motor need replacing.
Fuses blow for a reason. It's never a good idea to replace a fuse with a higher amp one. House fires can easily be started this way.
As for the motor, at this point the whole motor will need replaced.
Jan 15, 2011 | Beam Industries 2900 Serenity Plus Central...
My central air fan isn't blowing. The thermostat
Check the master circuit breaker at the power panel? Should be 2 50 amp vreakers. Turn them off rgen back on.
Jun 08, 2009 | Ruud UBHC Air Conditioner
Dometic air & analog thermostat control kit
Had one doing similar recently, and after a thunder & lightning storm. Nothing worked, but kept blowing 2 amp fuse in thermostat, when anything tried, heat or cool. Pulled plastic control box down from inside upper unit (AC) made sure breaker was off, took of plastic cover and smelled inside, and could smell burnt plastic smell. Replaced, control box, that got fan only working. Tried another thermostat , everything worked as it should. Turns out the lightning, or power surge, or whatever, shorted out the thermostat, and control box at same time.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
335 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
