Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer makes a horrible screeching noise while running and smells like something is burning. it's a maytag neptune
  • Anonymous May 14, 2009
    The screeching noise could be a v belt that is in it's last days. Or it could be bearings that are lubed for life, but guess what? The life span is close to over. The rollers that support the drum could be wearing out, causing the drum to be out of alignment. My Neptune only makes a noise after start up for a couple of mins. I'm hoping I can either change the belt or put some belt dressing on to buy me some time. Bottom line: Use it, maintain it.
  • 24 Answers
It sounds like your belt needs to be replaced. You're smelling the melting (burning) rubber.
Posted on May 19, 2009
Burning smell but not odd sounds
make sure vent is cleared MDG is a gas dryer so sometimes when theyre heating it may smell different than youre used to. blower impeller wheel has a "D" shaped hole & can round out causing it to hang up the motor which could cause a burning smell but usually will make a lot of noise B4 that will happen.
Jun 29, 2012 | Maytag Neptune MDG5500AW Gas Dryer
My maytag MAH550BWW has recently started making a horrible howling noise. It is otherwise working perfectly. It is draining good and not leaking at all.I have taken both hoses off the pump and found...
Had the nd error and smelled like burning wires. Read a review here and removed drain pump and a piece of plastic stuck in the impeller. Removed,inspected and reinstalled. Worked perfect! Thanks
We were heading out next day to buy new washer and dryer at $2000! Yikes!
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Gas Dryer will not spin when turned on. Drum spins by hand. Makes a buzzing noise and elecrtical (burning) smell. Dryer is unplugged now and vent is clear.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer is making noise, vibrating and smells like it is burning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fg
Jul 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Screeching noise
heatman101
sdgs
Jun 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Wont start, smells like something is burniing
if its electric burning smell,its either a overheating motor,capacitor or both or burnt connections,sounds like a motor problem,it will be very hot to touch if its failing,check capacitor though as it could be causing motor to overheat,rating of cap is on side
May 27, 2009 | Maytag Dryers
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
824 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
