Question about Garden
Tecumseh engine #143.985510 - carb linkage hook-up
I have a '98 craftsman push push mower that had a gummed-up & leaking carb, #640026. Fixed that with a new kit and cleaned out the tiny holes in the main jet. Now I've forgoten how the "fixed throttle" linkage goes back. There are two links coming from the govenor, a solid link to the carb throttle and a spring link to the solid mounted tab bolted to the intake. When I hook it up that way, the spring link pulls the govenor forward which holds the throttle wide open. Is this right? Do I have the solid throttle link in the correct hole on the throttle body? Thanks for any help.
JBY
  • 1 more comment
  • jby151 May 17, 2009
    What an answer. Not only did it solve the problem, but explained it in detail as well. Thanks again.
    JBY
  • Anonymous Mar 24, 2014
    No movement from the right side
  • Anonymous Mar 29, 2014
    I have a Craftsman lawnmower with a 143.944500 4 cycle engine.The throttle does not idle. The throttle link (funny bent wire)is connected to the throttle and it is possible to change the speed of the engine by moving the wire forward or back. However, the front end of the wire is not connected to anything and will not stay in one spot. What is missing? Or what am I missing? I have the owners manual but it does not show this wire connected to anything.(part 34336) it is called a throttle link. I don't know what it links to. Please help. Alice
  • 246 Answers
Hello:
The Carbuertor Throttle is Held in the Full Open Position Until the Engine is Started and Running, then the Governor and Spring Work together to Keep the Engine RPMs to the Desired Setting.
The Following is an Explaination on How the Governor System on Small Engines Function.
>>The Governor System behaves like an Unending Tug of War between One of Two Governor Springs, which Pull the Throttle Toward the Open Position, and a Spinning Crankshaft, which Tries to Close the Throttle. When the Load on the Engine Increases - a Typical Example is when you Move your Running Lawn Mower from the Driveway to the Grass - Crankshaft Revolutions Drop. But the Governor Spring is Still Tugging, Causing the Throttle Plate to Open. In Response, a Larger Volume of Air-Fuel Mixture Enters the Carburetor, Increasing Engine Speed to Compensate for the Increased Load. The Crankshaft Speeds Up, and the Tug of War Resumes, until a New Equilibrium is Achieved. With Each Change in Load, the Tension Between the Governor Spring and the Load Brings about a New Equilibrium, known as the Engine's Governed Speed. Neither Side Wins until the Engine is Shut Off. At that Point, without the Crankshaft Spinning, the Governor Spring Pulls the Throttle to the Wide-Open Position. Two Types of Governors are Common on Small Engines - Mechanical and Pneumatic.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • 2 more comments
  • John C Bridgers Sr May 18, 2009
    Hello Again:
    You are Very Welcome.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
  • Bob Beard
    Bob Beard Jul 28, 2012
    Thank's a lot Mr. John,I now fully understand how the throttle and governor linkage works.I believe i have installed everything correctly but the engine still will not run properly when engaging the blades.I have tried everything i can't afford to bring it to the lawnmower shop.The only thing i'm not sure of is the throttle cable position. Most of the problem i'm having is keeping the throttle wide open.I have to hold it wide open to get it to run right.Thank's again and God bless you!!!!
  • Bob Beard
    Here is my email address if anyone could help with this problem i would greatly appreciate it.cajunchefbob1062@aol.com
  • Linda Blessing
    Linda Blessing Jan 26, 2018
    Ok im having sorta the same problem. I need to hook up my engine control springs. I took a pic before disassembly however it got lost in the cloud.i have every manueal but they literally do not sjow me where to attach. Can you claim the woman card can somebody please help me I have a Craftsman 25 hp 48 riding mower with a kohler cv730s motor
How do you adjust the governor on my 143.676222 Tecumseh engine?
it is on the carb. side of the mower a arm comeing up where your carburator linkage hooks up that arm has a bolt on the bottom you loosen it and adjust the idle speed but a word of caution if you have never done this have a person with experience help you because it is not easy.
May 12, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a craftsman tecumseh 4.5 hp mower throttle free type and i have cleaned and rebuilt the carb replaced the carb mounting gasket between the carb and intake and also replaced the o rings on the...
1ec7ba32-45ac-4b07-8389-f863014e42da.jpgIt still sounds like a carburation issue. Are you sure all jets, vents and ports in carb are open? Another possibility is that the governor setting is off. The governor is the rod that comes out of side of engine and connects to throttle linkage on carb. To set governor to factory setting, push governor linkage in direction that opens throttle valve, loosen screw on governor arm and turn rod in same direction until it stops, while holding in this position tighten screw on governor arm. This is called a static setting. If this doesn't work I would disassemble carb, remove all plastic and rubber parts and soak in carb dip overnight. Picture may be different from your unit but it shows governor linkage to carb. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 18, 2013 | Garden
The tecumseh engine surges from medium to full throtle
If it is at full throttle and the engine speed lowers then raises again to full throttle - back and forth, this is a sign that the engine is starving for fuel. The most common area is the lower jet in the carb. has trash in it or it is gummed up. You would have to remove the bowl on the carb. to have access to it. Check with Tecumseh's website and see if they offer any info "parts breakdowns" to see if the jets come out of the carb. some are fixed in the body and you cannot remove. Good Luck.
Dec 07, 2010 | Toro Garden
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Apr 04, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Has no power
adjust the carbs fuel-air ratio and see if you can't get it to rev up
Jun 18, 2009 | Electric Lawn Mower
Carburetor linkages for riding lawn mower
Go to a tecumseh website and get a breakdown of the parts list and that should help a bit. Good luck.
Mar 24, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
2,474 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
