Question about Philips Televison & Video
Channel instalation problem
Philips tv model 32pw9586 lost manual cant install channels (when i press menu cant see anywhere install or something)
  • 1,305 Answers
Phillips' Website contains manuals etc for your unit.
I was able to view the manual for this model (their UK manual) here
This is according to the model number you listed...
I would print out a copy and keep with your files...
K
Posted on May 14, 2009
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
HI MY PHILIPS 25INCH TUBE T.V ONLY GOES FROM CHANNELS 2 TO 42
Either press menu on the Philips remote and go to autoprogram, or (if you have lost the remote), press volume - and channel - at the same time. When menu appears, use channel - to select autoprogram and volume - to select it.
-Tha Mp3 Doctor
Dec 31, 2008 | Philips TS2546C 25" TV
LOST TV MANUAL
Here is a website with the owners manuals for the television you specified. Simply click the one in your native language, presumably English and it will open a pdf file you can then save to your hard drive or print out if desired.
http://www.my-instruction-manual.com/product-guide-manual-user-instructions-philips-32pw9586-12-4914.html
Dec 29, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Philips tv Model 24RF50S141. I have lost all the AV input channels. Philips tell me that they have been lost from memory. Can anyone help me restore them?
I have solve the problem myself by going to channel install on the menu and advancing the channels with the right key on the channel line rather than using the channel up/down buttons. Which is partly my stupidity and the Tech at Philips failed to tell me. I was just racking my head and stated trying different things until I discovered the real solution. Besides at my age I have forgotten more things than ever learned!
Thanks for you interest!
John
May 30, 2008 | Televison & Video
Lost Instruction sheet for cl034
May 12, 2008 | Philips Magnavox Learning Universal Remote
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Dont seem to be able to install channells in
Auto installation should search for local tv stations, or add new channels, then it will search for new ones.
Feb 20, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Televison & Video Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
