Question about Mitsubishi WS-65809 65" Rear Projection Television
Convergence problem? I recently bought a 65 inch mitsubishi projection tv and it shows the menu a little blurry, but is readable. The background, however shows vertical lines. they almost disapear with the rgb adjustments under the tv, but i cannot get the menu looking perfect. In addition to that, i get hardly any change or response when connecting an av component (360), only a little added fuzz in the background. the menu is unaffected by the lines which makes me think its not a bulb problem? I only paid 60 bucks for the tv so i want to fix it. PLEASE HELP!!!
  • Anonymous Aug 30, 2008
    same problem with convergence- had tweeter here ,,,,want over $700 to fix!
  • 90 Answers
The menu is in green, so of course you won't see any convergence problems with only 1 color on the screen.
Go in and find the conv ICs, they will be mounted on a
big heatsink and the wires going to the conv yokes will
most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is
not unusual at all for them to need to be changed out
at some time in the life of a CRT RPTV.
Mr Bob
Comment by MrBob84, posted on Feb 04, 2008
PS -
The wires for the conv yokes at the CRT necks are the
thin ones. The thicker ones are for the hor and vert
sweeps, which must never be disconnected from their
circuitry during
CRT operation.
If your beam loses sweep on any of the CRTs, it will
instantly score/gouge your phosphors on your CRT faces,
vaporizing the phosphors there and ruining the CRTs.
The beam is very powerful, but in normal operation
moves incredibly fast, not damaging anything. Any
slowdown of the movement of the very powerful beam that
draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
Posted on Feb 04, 2008
  • 4,402 Answers
Posted on Jan 10, 2008
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
The picture on my Mitsubishi WS-65511 TV suddenly went blurry (looks like a 3D movie without the glasses). Is there a menu option that I can use to fix it myself?
No,tv have a problems known as a convergence problems,it is dead.This problems it is the tv board that call the convergence board it is dead.This convergence board must require to be replace 2 STK convergence ICS and some or all of it resistors too on the convergence board too.To fixed the tv convergence board to solved the tv convergence picture.The shop,will cost u like $300-350 for parts and labors.
Apr 19, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My rear projection tv is blurry and after i adjust the convergence, it goes back blurry again and i start over.
You have defective convergence. I have a tip at which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
May 12, 2010 | Mitsubishi WS-65809 65" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Jan 13, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Picture slightly too big
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 08, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
