Question about Malber WD1000 Front Load Washer/Dryer
Unit wont finish cycle
I set my unit to super wash... and it seems to never finish the wash cycle.  It seems to be stuck or something.  I am new to this machine, but it has never even gotten to the dry cycle.  i let it run for about 3hrs... and it was still washing.  please help.
    Problem Solver:
  • 13 Answers
It may be a control board problem. Contact Malber USA (info@malberusa.com) for assistance.
Posted on Jan 07, 2008
Hi, I have an Electrolux ESL 4115. It seems to be stuck on 50 degrees but wont start as usual when I close the door, the on/off button works and lights functioning as normal but that's all. Thanks
I had a similar problem - seemingly stuck or locked with a solid light showing (in my case on the 65 degree wash). Nothing seemed to unlock it. But when I closed it and went away to think about what to do next - some 5 minutes later - it made its end-of-cycle peeps. It now works fine. All I can think of is that I must have interrupted the previous wash cycle l was using before it had ended, and had left the door ajar. all it needed was the door closing for the cycle to finish. Does that help?
Sep 22, 2010 | Electrolux 24 in. ESI6220X Free-standing...
Ge super capacity plus washer. Mod wlse3150a0ww. no matter what setting it always starts on rinse then goes to spin.It also will not drain.
If the washer is stopped mid cycle it will default to rinse and spin. It will then get stuck in a loop. It is necessary to reset the electronics. Unplug the electrical cord from the unit. Wait 30 seconds. Turn the cycle selector all the way around clockwise. Turn it again and set it on any setting accept rinse or spin. Plug the unit in. It should begin a new cycle and be working normally.
Jan 22, 2010 | GE 3.2 cu. ft. Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Gets stuck on timer and wont count down
We had a similar situation with our LG washer. It was not a timer problem.
The machine was not entering the spin cycle and was just stuck in limbo. A sensor or something was not being satisfied and allowing the progression to the next cycle. Our problem had to do with the drain line; it seemed as if it was air locked?? After lowering the drain line height (to reduce the head pressure), and manually draining some water out of the drainage cap (where the strainer is located) onto the floor, the sensor became satisfied and the machine completed its cycles properly.
What told me that it was not a timer issue was the fact that on different wash settings (normal, heavy, quick cycle), the machine timer would get stuck at different countdown points (22mins, 12mins, etc.).
Jan 17, 2009 | Washing Machines
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Rinse cycle
Is the unit new or used?, or does it wait and then go ahead and finish? This would be normal if it finishes on its own. Some units let things settle between cycles. If you have to nudge the control past a point then to make it finish then it is a problem which would require that the control be replaced. If it used to work different then it too would most likely be the control unit. There are numerous contacts and combinations that change from one setting to the next. Bottom line, does it get the clothes clean?? If it does the don't fix whats not broken...
Jan 26, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
130 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
